- Oct 14, 2013
I don’t know Andromeda but the Amp8 has plenty of bass
Seems like my journey can't stop here so easy. My problem is that when using Andromeda with the stock Amp1 of DX200, treble and mid lost the quality and the only thing i hear good is bass. I'm not a bass head and this is super terrible and disaster for me. So do you guys think that upgrading to Amp8 will solve my problem?
What cable used?
When I bought Amp8 it made the DX200 a completely different DAP. It's less trebly and more bassy, but it's a very satisfying bass (and I'm not into unreasonably big bass either). Now, in comparison to Amp8, Amp1 sounds thin to me. Also, after upgrading to Oreo V2, I find my Andromeda a bit too bright with some worse quality recordings with Amp8. Also I'm using a not very expensive cable from Aliexpress.Seems like my journey can't stop here so easy. My problem is that when using Andromeda with the stock Amp1 of DX200, treble and mid lost the quality and the only thing i hear good is bass. I'm not a bass head and this is super terrible and disaster for me. So do you guys think that upgrading to Amp8 will solve my problem?
I just got my Amp8 3 days ago. However, today when I was using my dx200, I noticed that there was some distortion whenever I was listening to piano tracks. It sounds like a bit of fuzzy static whenever each piano key plays. It’s also somewhat apparent in other types of music but not as obvious as on a piano based track. Any idea what it could be caused by and whether I should do a 1-1 exchange for the amp where I bought it?
Stay updated on iBasso at their sponsor profile on Head-Fi.
Absolutely a beast of an amp modules! Love the Amp8, it has so much capabilitiesIt can take a while for the caps to form in the AMP8 and the rest of the circuit. The circuit is very sensitive to changes so you will hear these changes.
Now you mentioned it. I just used stock apkpure app and found the YouTube app. It is awesome APK app is stock app, you can get so many free appWhy don't you just use the youtube app?
Not familiar with these myself, but a lot of people report preferring Andro with slightly higher output impedance sources- maybe try adding a 2-3ish ohm impedance adapter?
