Sep 29, 2020 at 9:53 AM Post #93 of 404
Wow very good pairing. Thanks for being curious about this combination!!! Bass is more agile, the biggest change for me is better midrange transparency and vocals are expressed more clearly, treble is airier with slightly more sparkle. There is more precise positioning of instruments. There is better stage width while depth is rendered similarly.
Sep 29, 2020 at 10:01 AM Post #94 of 404
Thank you! You don't by any chance own the Noble as well to compare?
Sep 29, 2020 at 10:34 AM Post #96 of 404
. I believe @fokta measured at least one Dunu adapter, but it didn't look like the ones that ship with these cables. Thanks all
Yes... but it was gold plated.
dunu 2.5TRRS to 3.5 SE... (The top position)
very decent AVG 10mOHM impedance...
No (too much) coloring, IMHO.
just know that Dunu is making more cable... Noice...
Sep 29, 2020 at 5:17 PM Post #97 of 404
Blanche pairs way better with the Solaris. Get the Blanche. Cheers!
Just ordered the Blanche from MusicTeck. Hope they ship today! Thanks for the input!
Sep 30, 2020 at 5:02 AM Post #99 of 404
You won't regret it :) It's my go to cable
Musicteck ships blazing fast usually wouldn't worry!
Oct 1, 2020 at 1:03 PM Post #100 of 404
Blanche just arrived. Very limited testing, but sounds great so far. One thing that's bothering me...the connection seems very sensitive to contact...any movement causes static in one or both ears. Anyone else experience this? Am I doing something wrong? I changed from the 3.5 to the 2.5 before listening, and I'm 99% sure I attached it properly...checked several times. But it's still crackling when I move it, e.g., rotating the connection in my DX220.
Oct 1, 2020 at 1:06 PM Post #101 of 404
I had the same issue, it fades out quickly when using it just rotate it a few times in the socket and it should be fine quickly.
Oct 1, 2020 at 3:48 PM Post #104 of 404
Problem solved? I also wanted to take the Blanche to combine with ibasso220max, but I stopped because I read that it gives problems?
You mean the crackling? As @davidmolliere recommended, I just kept turning it and it goes away. I just went for a short walk, about 20 minutes, with the 220 in my back pocket, and I didn't have any issues. Will keep you all updated as I continue testing.
