Thank you.
DUNU Q-Lock PLUS Quick-Switch Modular Plug Cables - Discussion Thread
ngd3
- Apr 8, 2017
@HuoYuanJia you post some more color pics of the Blanche?
Received my DUW02 IEM cable (plus 2.5mm & 4.4mm balanced plugs) an hour ago. I am using this with my much loved Sony XBA-Z5. I had to re-attach each ear piece once to get them seated properly in the MMCX connectors, but zero issues after that so far.
This is my first experience with a modular plug-capable cable, and I've gotta say it is implemented much better than I could have hoped. What a great design.
While I have experienced subtle sound differences in (properly-made) cables in the past, that is not something I choose to chase. All I wanted here was good ergonomics, quality build with top-notch parts and the flexibility the DUNU modular IEM cable design affords. On all counts, my initial impressions are very positive.
Big ups to DUNU. I said in another thread, and I meant it: I am in the market for a mid-priced IEM, with the intention to purchase ~November, and I'll be keeping DUNU in mind while I evaluate/do homework on a bunch of candidates over the next few months.
HuoYuanJia
Previously known as Ultrazino
But... they were in color. You mean like this?@HuoYuanJia you post some more color pics of the Blanche?
More here: https://www.klauseulenbach.de/2020/07/28/dunu-blanche-is-it-the-cable/
I share my experience with the Blanche in more detail.
roygbiv6
- Mar 8, 2013
they should make the hulk cable green, it would look awesome
The Hulk looks really great in its standard colour. Its a cable that always looks very impressive when it catches the light but I would buy a green version in a flash. It does make total sense the more I think about it.
I've found a pair it matches well for it to live on & don't like to change them off too often. So would like another one as it is such a great cable you want to try it on every pair you own.
NickMit
Thanks for the review! Although I am a little bit worried now about the issue with contacts...
Getting a better sound is one thing, but if you need to constantly check the connection the difference will be neglected. Not to mention that problems with contacts can quite fast lead to more annoying ones as replugging will rapidly loosen the fit.
Has anyone else experienced similar problems with the contacts or it is an issue only with this particular model, I wonder...
HuoYuanJia
I would be lying if I'd say it wasn't bothering me. But my 2.5mm termination was probably the worst out of the box and the issue is now almost completely gone. I had it cut out one channel yesterday and after a "spin" the issue was resolved. But, yes, this is a cautious recommendation for this cable in particular. I would wait for some more users to chime in and share their experience.Thanks for the review! Although I am a little bit worried now about the issue with contacts...
However, the rest still holds true. I am still going through my music collection and I am 100% certain that the sound improved dramatically. I have a few piano recordings that were always harsh and sounded like they were clipping or distorting. It is gone now! I almost cannot believe it...
- Sep 27, 2011
No issues with my contacts here!
The first few times I used the Blanche I did have some scratchyness, but I inserted/removed/rotated the jack gently a number of times for maybe 30-60 seconds, and ever since it’s been perfect. I hope that helps! Also- I should mention that I wiped the plug with 99% alcohol as well (or use 90%; apply with a tiny bit on a paper towel, and wipe off almost immediately); I suspect this also might have helped.
I have to admit, I heard this cable at canjam andI initially just thought it was slightly more treble-y, but after spending some time with a Quicksilver tube amp and the Luna I am really, really impressed with the Blanche. There’s more to it than I thought.
physio
- Dec 8, 2016
Sorry to but in guys but here's a couple pics of mine for whatever it's worth. It's very supple and I really like it.
230inthird
Sorry to but in guys but here's a couple pics of mine for whatever it's worth. It's very supple and I really like it.This is the Blanche
- Sep 27, 2011
@physio - nice pics! I need to get the 2 pin version eventually as well.
The Blanche is so darn supple and it’s very, very nice.
Some quick pics of mine:
davidmolliere
Nice pics!
I am ordering Blanche as well imminently
Could someone guess how this might compare with FiiO LC-RE? Having trouble choosing one.
https://www.head-fi.org/threads/fii...le-for-fiio-shure.930572/page-3#post-15794304
Blanche connected to the CIEM of my choice.
Lovely pics. Camera and lens used?
HuoYuanJia
Thank you! I'm a micro-four-third shooter. I use a Olympus E-M5 II. This lens is the M.Zuiko 60mm f/2.0.Lovely pics. Camera and lens used?
However, I don't really recommend it. I bought it very recently as there was a 100€ discount. Up until then I was using the M.Zuiko Pro 12-40mm f/2.8 and it gets fairly close even with macro shots. (Anyway close enough for IEM - maybe not for tiny insects.) I think the Pro also has nicer Bokeh too.
