I do know they require a good amp... I meant in the next months I will buy both or either and the other maybe a year off.
I'm puzzled though, I read that the STX supports 600Ohm output via a three way setting in the configuration panel. Will it not be sufficient?
Wankski, since you seem to have tried lots of stuff, want would in your opinion be :
a) The cheapest portable amp that would make the DT880/600Ohm sound "good".
b) and I don'r really want to go there but... the most comparable HPs to the DT800/600Ohm that do NOT require an amp?
hey man,
yes they definatly require an amp... wrt the stx card, they can write on the card what they wish, its marketing.. much like even crappy speaker manufacturers quote an operating range from 5-55khz BS...
the thing as you'll know after doing a search that 600ohm amps need, its VOLTAGE. an internal soundcard has max, what? 5v? whats more, whats matters is what the amp section can put out in Vrms terms which is typically a much smaller number.... My m3 for example has 24v coming in, but it capable of a steady 4.5Vrms or so... this is important due to the relationship of:
P = V^2/R - this is why voltage is critcal with high ohm phones... 600 is a far bigger than 32 or even 70ohms obviously so u need much more voltage to drive them... this typically means mains powered desktop amps... to give you an idea... on 600ohm phones the power that my amp can put out is only 32mW or so... max... dropping down to the 250ohm variants of the SAME phone u get 80mW - don't forget this is all off a 24v mains powered source... but note: 250s also definately require good amping, its just that 600s are even more dependant on good voltage supply as well which makes things even harder....
your question a) is what scares me... cheapest portable amp that would 'properly' drive 600s... I haven't heard of one... also the word 'cheap'.. they may be amps that have enough voltage to drive the 600s but they may not sound good.... remember having an amp introduces something in the chain that can color the sound - introduce artifacts or just plain sound bad... hence u need voltage and decent quality. personally speaking my m3 amp is the only thing that blew me away while listening on my 990s and unless u build one, they will set u back at least $350USD to acquire one built ex shipping AFAIK... equivalent commercial amps will run you probably 500USD plus... That would be about the price range on up where i expect commercial units that would do high end 600ohm phones justice.
that brings me to my next question? as far as i can tell u haven't sampled the 880s? this so? In which case what brings you to the conclusion you want them? Seriously, everyone's taste is different. I suggest you figure out how u can try out some phones and at least get some sort of idea of what u like and dislike...
That said, some off the shelf phones that are well regarded that require no extra amping at all include allesandro ms1is or their grado equivalents ( i personally did not like their sig, and i sold my ms1s...) but more relevant IMHO are something like Audio Technica AD 700 and AD900s... very good phones that will sound good off even an iPod... you may want to check out sennheiser, i personally rate the AD900s higher but u should be able to sample sennheiser at any decent hifi store or even record/cd shop.... models that do not require amping include the HD555 and HD595s... another lead may be Shure's line of head phones like the 440s or 840s.... they are closed which may be something u'll like since u're into 'portable' and probably want to take ur phones with you and have a degree of isolation... if so, u may want to look at beyer's own DT250s... damn good closed phone that comes in a 80ohm variant which will be far easier to drive than 600s... check out a lot of radio station's headphone monitors.... a lot of them at dt250s for a reason...
personally, iffin i was u i'd try to sample some phones and get some idea of what u want, and then make a purchase decision... but given your indicated preference to skimp on a decent desktop amp to power them, i'd avoid the 600s and get just about anything else... or even better something that doesn't require an amp...
I really hope that helps and doesn't come off as condescending or anything...
I just want to add that what kind of phones u like will depend on what kind of music u listen to.... on some music my 990s absolutely cain with the bass and its fun... but on some music they do not sound good (see the trademark beyer 990 sibilance issue) for some tracks i'd go for something else.... see people's opinions on another hard to drive phone, the akg 701. some people may listen to classical music and may love them, other wonder what the big deal is when they listen to modern music or maybe even techno and think the phones to be sterile, devoid of bass and no fun... opnions vary... there is, by and large, no pie in the sky 'high end' phone that is categorically the 'best'. since u wanna hold on to your next purchase for a while, make sure u like em after making an informed choice...
