I got a response from Don - essentially it is not a drop in replacement having "higher plate impedance and lower transconductance", but he gave me the go-ahead to use it in the amp, with the caveat of not using one of the various bulk suppliers from Russia or whatnot due to the inconsistency of these tubes in general on section matching. The Tube Store does section matching for $5 and total shipped for one tube to the US is $35.
I instead did a little more digging and found that the Rhombus 5 designated tube is a military spec higher grade than regular OTK and can be had with a gold grid, saw one report in a Little Dot thread how this tube has better frequency extension. Found a couple sellers in Bulgaria selling matched sets and publishing the measurements, picked up this nearly perfectly matched set
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=300588842688&ssPageName=ADME:L:OC:US:1123#ht_5248wt_1082
Note that these 2 Bulgarian sellers seem to copy themselves w/ photos descriptions for their auctions so that seems a bit sketchy, but they're both from the same city so it might be the same seller using two different storefronts. They both have a ton of feedback and sell primarily tubes, appear to be legit looking at their auction history, specs (unique in the listings), etc.
jc9394, yeah, I don't know what it is, not sure of the condition of the mullard but the metal base tube measures 52/52 (min = 40 and new = 60 on TV7). All I can say is general impression of this tube and how people describe the improvements w/ other audio gear seems to be close to my experience. Having about 12 hours on it now, and going back to the mullard a half dozen times, I would characterize the changes as 1) less energy in upper bass/lower mids, which in some ways reduces PRaT a bit but increases clarity/detail here, 2) less upper mids glare, but overall mids seem more forward, 3) way more treble extension, detail. Hate to be cliche but it's the typical "veil has been lifted" sort of experience. It's enough of a change that if I keep the Sonett (as you may know I have a maxxed WA6SE on the way) I'm going to get another couple of these as backups, although I am curious to try a big brown base mullard as well, which is supposed to be very close sonically but tipped more toward the bass. I simply can't listen to the small base mullard, sounds too fuzzy bloated. I probably should get it tested locally though just to make sure I don't have a weak tube. But it did sound good to me before getting the metal base, it was just one of those things where my eyes were opened a bit wider.
