Well, I've got the stock JJ, a Shuguang and a Sovtek rectifier. Using the JJ tube made me the most happy and comfortable to the point of more or less just enjoying the music. The Shuguang has a edgy sound to it and the Sovtek is in the middle of the two, but still leaning towards the slightly cold side.
I have the stock Sovtek driver, an Electro-Harmonix and the Reflektor super tube. I feel the Electro tube improves upon the stock Sovtek tube in a few ways. A little warmer balance and a slight tighter bass and maybe a slight improvement in transparency. Nothing drastic at all, but between it and the Sovtek, I preferred it. Enter the Reflektor. Simply put, there is no doubt in my mind that Reflektor tube improved upon every part of the amp's presentation. Like I just opened a window. Like I took away a layer of grunge. Like I unwrapped a great food item from saran wrap and can taste and smell it now, or something like that. A whole 'nother level in performance. Not a baby step like the Electro tube did, but a clearly hearable improvement. Bass kicks had more heft, soundstage had more precision and deeper depths, sibilance lessened, ride cymbals had more clearly defined drum stick hits, and everything in between. Absolutely worth the money.
I accumulated 50 hours on the dot with the Reflektor tube, then put it away and had the Sovteks in both spots. I listened for three sessions and decided they're good together, but lacking a bass impact and overall clarity and smoothness the Reflektor brought to the system.
Enter the CV1377 tube. Two hours of white/pink noise burn in, then sat down and gave it a whirl. What the Reflektor tube does, this tube does also, only to the next level. Whatever I said about the Reflektor, the CV1377 did again!
The bass heft and impact improvement, a midrange clarity opened up, the smooth top end didn't get smoother, but there's a more defined shimmer to the cymbal, the imaging and depth became a bit more solid. Again! And that's with low hours on it.
Right off the bat I was enjoying the music more than trying to critically find what's wrong. I listened all night long, and about two hours past my bed time.
Mandatory equipment for the Sonnet in my opinion. Don't even bother with the other tubes, go straight to the Reflektor 6H30P-DR, and the Mullard GZ34/5AR4/CV1377.
Now the rectifier tube is at 16 hours and 30 minutes of use, and the output tube is at 66 hours and 30 minutes.
That was supposed to be much shorter than what it ended up being.
