pwrusr
- Aug 15, 2003
bump
Originally posted by wallijonn It would be interesting to diagram a new headphone, then compare it to one that has been burnt in, and lastly compare it to one that has been burnt in and has been playing for an hour. |
Originally posted by wallijonn they may look the same, but are they matched to the amp? if they are not matched to the amp, they will sound different. if the minimum (nominal impedance at 1 KHz) does not match the measured static impedance of the headphone output, as the amp drives the headphone, the resistance will change due to greater heat caused by voltage/current. when the new headphone nominal headphjone impedance matches the amp static impedance synergy will occur. |
Originally Posted by luukas Urgh, I wish now that I'd never browsed through this thread... HD25-1 |
Originally Posted by luukas Urgh, I wish now that I'd never browsed through this thread... |
Originally Posted by Steve999 Psst... I don't think j-curve got a good seal on that one. I heard them at a head-fi meet and they sounded pretty good. Check out headroom's measurement: Headroom HD25 FR Graph Pretty good for a lightweight high-isolation closed phone. So cheer up. |
Originally Posted by luukas Ahh. The HD25-1 graphs weren't listed in the measurement lists... instead I found something, well, interesting: http://headroom.headphone.com/graphC...are+Headphones That HD25-SP graph looks very similar to the 25-1 graph seen here, in fact almost identical. What's up with that? |
