300ohm Blue Glue in the most terrible to work on shell ever. Slightly darker tuned because of forward female vocals. Very good technicalities despite the darkish tuning, big and punchy well textured bass, very detailed in the mids.
After comparison with a few other buds I have to say it is not the most natural sound. Maybe the tiny shell with low air volume is at fault? For now it may stay in there, but I might want to try the driver in a different shell at one point. Works well with electronic music, not so good for acoustic music.
I'll name this one "Donkey Honk".
Next up: 130ohm Bery with 1,5 mm Bass tube through the fake bass port.
Making the bass port a real bass tube was fun and very rewarding, super happy with how that worked out and looks! It actually extends about 1,5 cm into the shell, so is about 3 or 3,5 cm I guess.
Sadly when I closed the build the first time there was next to no bass however and jarring treble! So first I exchanged the stock tuning paper with Y2. No change!
Step by step I had to drill 5 (yes five!!!) 1 mm holes and also made the stock vent holes a tiny bit bigger with a 1,5mm drill bit. At this point it was sounding balanced but with quite a big bass boost, treble was where it needed to be. Also the bass tube now literally had no influence on the sound which I found out when sealing it with my fingers while listening!
Bass was also a bit softer than I like.
I then exchanged the medium to a high density horseshoe, as in another build this tightened up the bass and made it punchier without any real drawbacks. Here it added bass and reduced treble quite a bit. So I was able to seal 3 of the 5 1mm holes I had drilled. Now it sounds absolutely great with strong bass, great clarity and sparkly treble. The treble can be a bit spicy on certain tracks, but in general it balances nicely with the big bass. When now closing the bass tubes with the fingers there is at least some change to the bass response, but the bass tube seems to be more of a gimmick here sadly. I think the diameter of the tube is too small for this driver, and the driver "breathes" mostly through all the other vent holes. The bass tube should work better with drivers that don't need as much ventilation as the 130r bery I believe. I might try this mod on my 400r graphene build.
While this build sounds fabulous now, I am a bit surprised that the staging is not especially noteworthy or deep, seeing that the frequency response seems to be balanced with a healthy lift in both bass and treble. The dynamics and transient response of the driver, while not bad seem to be not on the same level as the 400r graphene and especially the 300r bg "donkey" driver...
I will name this bud "Blackbery"
I am having a few days off (the family is away too!), was very industrious and also retuned the Faaeal Rosemary with the 150r blue glue. It sounds fabulous as well now! I think the technicalities of this driver might be a tiny bit ahead of the 130r bery as well (not sure!) because I don't miss out on details, even though there is a bit less treble. Staging is similar on both. The Blackbery is a bit more exciting, a bit like retuned Rosemary on steroids.
Btw, I would like to thank
@metrics again for taking the time and making
this great post, it supplied me with some much needed background information about the different tuning materials and what they do. It is what finally made me really get into DIY. A higly recommended read in addition to the DIY guide
@konyvkukac and anyone else interested in doing DIY.
