DIY Earbuds
Jan 15, 2025 at 4:00 PM Post #4,967 of 4,979
Do you have the link for these shells?
Those shells are from the QKZ MDR earbud, you'll have to remove the drivers and cable from the shell to use it since the shell isn't sold by itself anywhere.
Jan 18, 2025 at 9:17 AM Post #4,969 of 4,979
How do you guys tune PK1 shell? The horse shoe foam does not fit quite well.
Jan 24, 2025 at 11:36 AM Post #4,971 of 4,979
Does anyone used plug adapter like this one:
Jan 24, 2025 at 11:51 AM Post #4,972 of 4,979
I use thin HS but unfortunately they are no longer found, I still have them.
Try with white tuning paper (Y)
Yes, I wanted to check if the thin horseshoe was available again, but found that the option of the dense horseshoe has now disappeared as well. 🥴
Are there other shops to check other than XinYue and NSCAudio? I have bought all the tuning materials from them so far...
Jan 24, 2025 at 11:11 PM Post #4,973 of 4,979
For me yes, the rest of the stores have high prices compared to the two you mentioned
Jan 25, 2025 at 7:55 AM Post #4,974 of 4,979
Jan 26, 2025 at 8:21 AM Post #4,975 of 4,979
Jan 26, 2025 at 11:39 PM Post #4,976 of 4,979
Jan 27, 2025 at 8:19 AM Post #4,977 of 4,979
Made a small experimental thing: open front cup(on photo) vs classic standart mx500 cup.
Resulsts:
https://makeitrio.github.io/measurements/?share=RIOBuds_open,RIOBuds_close
Sound: more warm, more natural, no brights, better extensions on highs
Awesome work right there man. This give me some idea :3
With the unmodded faceplate, i found the stack height (distance between the diaphragm and the inner side of the faceplate) can be too small. By doing this, it can introduce some new room to work on. Thanks for the idea lol
Jan 29, 2025 at 9:46 PM Post #4,978 of 4,979
Hi All!
I got a bit burned out on earbuds for a while, so sorry for the absence. :triportsad:
That said, I'm wanting to put together a few buds using MX500 shell, and looking for good cables for it. I checked out an earlier suggestion, but they are no longer available.
https://www.aliexpress.com/item/1005002233206762.html
What cables are people using that fit mx500 shell these days? Any suggestions? Maybe on the flashy side? I don't mind cutting off the connector as long as it will fit into the mx500 stem.
Jan 29, 2025 at 10:10 PM Post #4,979 of 4,979
Hi All!
Xinhs cable for the most part. Specifically the 2 cores type (one that similar to Rikubuds upgrade cable) and the 4 cores cable, those that have the diameter of 1.2mm and less
