weedophile
Ahh that sounds depressing. Nvm i shall order myself some drivers from taobao and do it from scratch. Till then!
hope your ears are better. any update on how these sound?
Hi,
I'm wondering, what are the rules of thumb/theory when modding/creating new earbuds? I'm at complete beginner at modding, but it seems there are several things to consider;
- holes on the back of the body. What does it do to the frequency response to either create new/larger holes or fill existing with material? What does the distance between holes have of influence? I'm thinking about the theory of creating a subwoofer, where all this is well described. The wavelength of bass frequencies seem huge compared to any possible distance between the holes, does it matter at all? Or does it matter more to mid frequencies?
- what does adding of "horseshoe cotton" do to the frequency response? Or several? For example https://www.aliexpress.com/item/Earbud-headphones-horseshoe-tuning-cotton-Ear-noise-cotton-Leakproof-sound-speaker-unit-complex/2036360886.html
- what does putting "something" in the chamber, thereby making the chamber smaller, do to the frequency response? What is the effect of different materials (ie cotton / hard material)?
- the small holes in the front of the earbud are mostly extremely small. Any benefits from making them larger? Some earbuds only have holes in the outer part, not in the center, does this make the sound "bigger"?
- cable. Matters or not beyond a certain quality? I've had silver interconnects between stationary units and that definetly made a difference (to me..).
- plug. Rhodium seems popular, I've ordered but haven't received. Seems that rhodium results in more treble compared to gold, which is rounder in freq response. For example with Edimun v3.
I cant find a guide to this and more, even though I believe it should be possible to make one..
Anyone have a good app for iphone for measuring the frequency response? I know it will not be exact in any way, I'm just interested in being able to make relative measurements before/after modding.
Thanks for input
bro. What kind of reverberation it affect? is it desirable or non desirable reverberation? Does it also effect bass resonance?Horseshoe cotton will affect different drivers different depending on the shell. Again, a thing experimentation will let you know best. But, generally they are used to prevent reverberation...
In the case of channel imbalance, Left sounds louder than Right, is this solved by switching the wires in the Right driver or vice versa?
You may try blowing some air or vacuuming to the front cover/behind the driver to the left driver. It sounds odd but this method worked on my SHE3800.
That also solved rattling sound on SHE3800 and LZ Z03a. Hope that helps
I had problem with qian39 rattling bass. Did the same. Slow blow into the driver. Help with qian but not working with she3800. We'll I guess now one of my she3800 not working at all it must be something else.
On the side note. I can't shake the feeling that qian39 sound less impressive after thorough burn in. I like it when it's new. Tighter sounding.
yep, same hereI had problem with qian39 rattling bass. Did the same. Slow blow into the driver. Help with qian but not working with she3800. We'll I guess now one of my she3800 not working at all it must be something else.
I have both. The recable and reterminate sound brighter compared to stock. I found newly arrived qian39 sound best. After 1 day listening to newly arrived qian I gave it to friend for audition. He use it around 20-30 hour and gave it back to me. it still sound impressive. But after 50 hour it started to sound different. Less engaging. Before burn in I don't have to look into music. It came to me. Not long after burn in it started to get lazy and I have to. seek to the sound. As I said before it became less engaging.terrible stock cable, replace that asap IMO
Not sure what happened though. I might save one pair and listen back after left it for a while to test
It still very good though. But I like it better when it's new.
