jmpsmash
it will be useful to know your budget and requirements. what are you trying to improve with a new cable?
Yes I am. But I'm mainly needing one for my m1060 because I bought some el cheapo and it's short. I am a experienced solderer. I just need the type if wire I need and the way I connect the end connectors.What is your budget, m1060 are 2.5mm jacks but the sundara are 3.5mm jacks, are you building for both.
Buy a 2 metre length of Mogami 2893 or Van Damme starquad, 8 metres of 3 or 4mm 550 paracord, 2 x 2.5mm mono jacks and your end jack ie 6.35mm or 4 pin xlr if you want a balanced cable ( you will need a balanced out on your amp), you might also want a splitter.
https://www.cosmic-cables.co.uk/build-your-own-headphone-cable
i don't know where are they made, but bought many cables using this kind of plugs from that shop, and can affirm their quality is quite superior than usual chinese knockoffs.Hey, does anybody know anything about this outfit making connectors out of Taiwan?
https://www.aliexpress.com/item/100...1.0&pvid=c4c5aa67-b40e-4a62-970d-c09e71387682
https://www.aliexpress.com/item/100...1.0&pvid=bae81098-ce2f-41d0-a0d7-4097bfc96dbb
They look suspiciously similar to stuff sold by Satin Audio, Toxic Cable, and Eidolic — indeed, the two-pin connectors (second link above) appear to ship in nearly identical mylar packaging to the Eidolic ones I've bought. I'm wondering whether anybody knows if these are simply knockoffs, or whether they might all be made in the same factory. I love me some Eidolic connectors, but my success rate is not high enough to keep using those until I get a little more reliable with a soldering iron.
ghentaudio's usb cables?i'm fed up trying to corrall my anaconda-like Tellurium q usb cable with audioquest Female USB B to micro usb male adapter to connect to my Hugo2. No matter how try to secure it, it is still placing stress on the port. It appears no one makes a cable version of this, which leaves me with the option of making one. Has anyone here any experience of make usb cables and or found a supplier for decent quality connectors? thx
the offending article:
https://www.ghentaudio.com/usb/u08.html
guess you could ask for USB A male connector instead of female.
yea, it's not worthy to mess with tiny usb contacts while Ghent does the job very well at very reasonable price. i already bought about 5 usb cables there.thank you for this. I emailed and had a response within an hour to say they could make one and post it to uk all for $25. Perfect thanks and its quite a relief, as although i love making most audio cables i think life might be too short for sweating over one of these. Thanks again![]()
