unless you are buying from an authorized dealer or someone you know and trust, assume it's a fakeFurutech 3.5 TRS jack.
I heard that rhodium coating is wear off fast then underlying copper layer will appears.
I don't think this jack is counterfeit one. Want to buy this interconnect cable.
But the seller kindly told me that thing.
Any one can help to confirm the coating on Furutech?
DIY Cable Questions and Comments Thread
TYATYA
That is trust audio shop I known by years. About 10k audio stuffs I paid there so I think they are not spoofing me with a small goods like this.
They tell me to prevent me from buying, not try to selling.
Also I have 2 pcs 3.5 to dual RCA from Furutech, and really they wear out faster than jacks from switchcraft, ediolic, fiio...
Here's my first ever attempt at a DIY cable! Made with Canare star-quad and 275 black and midnight blue paracord. It turned out pretty good if I do say so myself!
One thing I noticed though, it that the microphonics are worse than the stock cable. Anything that touches the cable can be clearly heard.
Does anyone have any suggestions as to what I might try next time to eliminate the microphonics? Also, what are the main causes of microphonics? Is it the sleeving? The insulation of the cable? The style of the braiding? For instance, would I get less microphonics if I left the 4 cables inside the canare star-quad twisted, and just put one larger-sized paracord sleeve over all of it? Or maybe don't use sleeving at all?
Do they make paracord larger than 7mm? Or something similar that is 7mm or larger?
Tight sleeve is usually not good for noise. Next time try looser sleeveHere's my first ever attempt at a DIY cable! Made with Canare star-quad and 275 black and midnight blue paracord. It turned out pretty good if I do say so myself!
I'll try that! would you recommend going up a paracord size, like 325? Or should I just not stretch the 275 so tight (like, use more paracord than necessary so that scrunches a little so it's looser).
not stretch it so tight.I'll try that! would you recommend going up a paracord size, like 325? Or should I just not stretch the 275 so tight (like, use more paracord than necessary so that scrunches a little so it's looser).
I need sleeve larger than 7mm, any thoughts?
nereus
- Dec 1, 2014
Would something like this work?
https://www.aliexpress.com/item/Cli...1b-4b6f-b549-24d8993f00b1&transAbTest=ae803_4
Maybe techflex is the way to go for larger diamter
I'll have to look into those. Any other suggestions welcome.
taiyoyuden
- Sep 4, 2009
Will an XLR microphone cable with an adapter on each end work as an unbalanced stereo headphone cable? I ask because most mini XLR connectors seem to be low quality and difficult to assemble.
AKG K702 -> Mini-XLR Female to XLR Adapter Male-> XLR Female to XLR Cable Male Cable -> XLR Female to TRS 1/4" Male cable adapter -> Amp
I believe mic cable is 3 wires and balanced headphone is 4.
I just realized that, PET will not work as I want so use it for a headphone cable. I was going to use 1/4 paracord and it is just a hair to small. What else is soft, and will not have too much or any noise can I use for Mogami 2893? this is the main body.
I'm going to attempt to use a spare shoelace soon, because I feel like it would be very soft and flexible. I'll post results once it's done.
Paladin79
Previously MOT: Cables For Less
I use a combination of cotton and PET, the cotton sticks up more than the pet so it is really not very microphonic.
https://www.ebay.com/itm/Braided-So...var=441856022940&_trksid=p2057872.m2749.l2649
the 4 mm flat stretches to at least 9 mm diameter.
Total: 15 (members: 0, guests: 15)
