Awesome! That looks good.
Connector? You mean at the source? I have a few Eidolic plugs already. I'll use those.
I posted this wire a couple pages ago I think, it says it's OCC, so should be at least OFC I guess. 1,1mm OD and 110 Cores should be good for what you are trying to do, definitely enough AWG. 1.1mm should go fine with Paracord Micro or Type I. My 10m haven't arrived yet, otherwise I would upload pictures. 4 of those easily fit into most 2.5mm TRRS Plugs. Just make sure your sleeving is nice and tight and you should be fine?
Which connectors were you thinking about using?
So usually what you would want for making a new cable for a DT 770 Pro is a cable with a twisted pair and a shield. You would then on both sides use the shield as ground and the 2 conductors for left/right. Now if your cable has shielding you can use the shielding as a common ground and 2 conductos for each side, or you could connect the shielding to ground and leave it unconnected on the headphone side, then 1 conductor for each sides ground and signal connection. Or you ditch the shield and do it like Paladin79 said.
And you will want to pre-tin your connector and wires. Put a little flux on the contacts of the plugs and pre-tin those. Then pre-tin the wires, also using flux. If you want to use the shielding, twist it together, use a little piece of heatshrink over it and you can pre-tin it easily, again using flux. I personally use halogen free, no clean flux and eutectic, lead free solder with a high silver and a small gold content, but usually any lead free, eutectic solder with like 3-4% silver should be perfect for those kinds of connections. Most of those solders don't have very good wetting behaviour (is that what you call it?), so that's where some of that extra flux comes in handy. You don't want to use too much of it, but it's actually hard to mess up when you use common sense.
About your connector, just like Paladin said: It is a standard 3.5mm TRS. TRS means Ground on the sleeve, right channel on the ring, left channel on the tip. There are pictures all over google about the pin-out of TRS connectors, for checking your work you can just check with a simple multimeter. If you don't own one, I think you can get them as low as 10-15$.
I happened to be helping my employees build some cables and here is an example of a quality 3.5 mm connector with stranded wire going through solder lugs. There was no pre-tinning necessary and this is a high strand count OFC wirethat went through the holes in the solder lugs easily. I solder the braid to the clamp on this amphenol connector after using a hex crimp to form the clamp into a nice circle around the cable jacket. Finally there is a side view showing that braid clamp as well as the solder lug with the entire opening filled. Done properly the clear insulation slides easily over all connections.
These are solder joints that will last for years since the wires are not just tacked onto the side of cylinders as shown in the earlier discussion.
