Eudis
- Sep 6, 2014
These the 2.5mm Jacks I used: http://www.vetco.net/catalog/product_info.php?cPath=72_90&products_id=6830
It's from plussoundaudio. It's under diy.
I'm not liking it. I overmeasured the amount of heatshrink and it spins around too much plugged into my phone. I'm going to re-terminate to a strait 3.5mm plug.
did you use epoxy to secure the female jacks in the cups, or did you just use the nut?
Hi there,
This is my first post sorry it's a question. I've been reading this forum for a few years with interest and have recently moved into the financial abyss, I mean hobby, that is headfi.
I own some first generation T1s and recently purchased a Phasemation EPA-007x head amp. The EPA is dual mono so I have re terminated my SE to dual 3 pin XLR. My question is what to do with the sheid wires? It seems some say insulate and leave floating i.e do not attach and some say attach to the ground lug on the XLR. I'm confused what should be done with the shield .
I have the same question regarding shield as I'm making an adaptor cable SE with dual 3 pin XLR female so I can still use the T1s with my Metrum Aurix amp, do I not attach the shield or attach? Or does it not matter either way. To add, I'm using some mogami for the adapter cable which being a single cable as opposed to the T1s twin, I only have one shield wire so if I need to connect sheid would I half the shield so one half goes to left XLR and the other to the right XLR?
Any advice would be gratefully appreciated and accepted. I have asked several cable makers but either they were not too sure or simply didn't answer.
Sorry if this is a basic question, I did read this whole thread but seem to have read conflicting answers, assuming my understanding is correct.
Thanks in advance, with respect, Simon...
I'm trying something that I though would be easy, and now I'm worried. I'm making a cable for an HD800 for a fellow head-fi-er. Holy crap, them pins are tiny. For those that haven't seem them:
Yes, that ridiculously tiny thing on the right. To make it worse, I think one solders to the smaller wires on that thing!
That's like a 2mm surface to solder, with 1mm separating them!
So, I'm looking for hints and suggestions on how to get this right. I hear these things melt easily too, so I don't want to do that. The pair of connectors is like $45! What the hell was Sennheiser thinking?
Those are not any smaller than the connectors used in MrSpeaker's cables.
Third hands, and a lighted head magnifier and you should be good.
http://smile.amazon.com/SE-MH1047L-Illuminated-Multi-Power-Magnifier/dp/B003UCODIA/ref=sr_1_4?ie=UTF8&qid=1460686632&sr=8-4&keywords=lighted+magnifier
I tin the wires, put a little flux on the connector, clean my iron, put a little bit of solder on the iron, get the wire in position, touch the iron to the solder cup/wire, done.
For anyone wondering how to make splitters like the one below, get some siphoning tube (I'm not totally sure on the diameter, 3/16" or 1/4" depending on whether they measure from the ID or OD), push the sleeves into each end of a 1-1.5" piece of that siphoning tube, then insert the tip of your hot glue gun inside an opening and fill it with hot glue. Afterwards use some 3/8" heat shrink tubing over the top of it and make sure that heat shrink tube is about 1/4" longer than the siphoning tube. Heat it. If you want to get real fancy, put some clear heat shrink over that.
BOOM.
