Arty McGhee
- Apr 14, 2014
Making my very first cable ever for my HE-560 with 2 separate 2.5mm cup connectors and I need to figure out the various sizes of heat shrink to purchase for:
- 2x 2.5mm connectors?
- Y-split over 4-braid to 2x 2-braid
- ¼" Connector
- 3.5mm connector?
- Braided Paracord over 26awg to connector
I believe I'll need very small diameter for the connectors to isolate within the connectors after soldering, but what size and where do I get clear?
For the stuff that can be seen outside the connectors, what diameters? 2:1 or 3:1?
The options exploring at http://www.avoutlet.com are massive! (except I cannot find clear there)
this is pretty much all i use these days
its 3:1 so it will go down to 1/8" and its adhesive
so it holds everything together like hotglue
http://www.markertek.com/product/mac-11630/dual-wall-heat-shrink-tubing-8-piece-pack-3-8-inch-x-6-inch-clear
