Yep, that's the stuff I am planning on getting. I will also get mogami 2893 wire and this Switchcraft 35HDLBAUS plug so I can use it with a 3.5mm jack, and screw on a 1/4" jack in a pinch. I'm also thinking of this Carbon Fiber Micro Y-Split Cover from Double Helix Cables.
Cost of cable:
MrSpeakers tips: $14 (shipped for free sine I got them with my headphones)
Cable (6'): 5.64 (free shipping from Markertek)
Plug: $7.69 (free shipping from Markertek)
Sleeve: 7.84 (shipped from ebay)
$35.17 if I use heat shrink for the Y split
Quite the deal. Of, if I want to get a little fancier, I can add:
Y-Split: $16 (had to throw in an adapter to get cart above minimum order of $15)
So, $51.17 gets me a decent portable cable with a fancy Y-split, plus an adapter! I love DIY.
Umm, the small openings on the Y split are 4mm. Will that accommodate the two wires from the 2893 and tech techflex nylon sleeve?
4mm should be big enough. The basic 1/8 " connector is 6mm I had to ream out a 1/8" connector to fit 4 paracord covered wires. So two wires with that techflex should fit just fine.
