creatip
- Jun 28, 2014
Hello All,
I would like to do a cable for the coax out of the Fiio x5
3.5mm to Coax
What type of wire should i use?
Moreover i'm not sure of the connection i have to do on the 2 termination.
Your advise will be really appreciated.
cheers.
By definition, coaxial connection/cabling = 2 polarities only. Furthermore, coaxial is mostly used for digital signals, not analog.
Looking at the X5, it's not that the jack can 'convert' coaxial (digital) to 3.5mm (analog), but rather the jack can accept 2 kinds of plug/connector, analog line out and digital coax out, and adjust the output accordingly. Another example of this kind of plug is the Astell&Kern DAPs, where it got 1 jack for 3.5mm and optical.
Now what are you planning to extract from the X5? Analog or digital signal? For analog, get a 3 polarities 3.5mm and cable with 3 polarities (or 3 strands). For digital, maybe get a 2 polarities 3.5mm and coax cable (I'm not too sure about digital coax plug)
