funch
If size 6 is 6mm, then this one: http://www.canford.co.uk/Products/20574/39-326_TECHFLEX-EXPANDABLE-SLEEVING-Fray-resistant-size-6
Can someone tell me which would be better for sleeving 26 gauge cables, 275 or 550 paracord? Each cable would be individually sleeved; also, these are for my hd600s. Thanks in advance!
Having real difficulty sleeving my Canare Starquad individually into 2mm paracord. I know people have this before, what's your method?
Hey what kind of cable and connectors do I need for a digital coax RCA cable? I thought I read somewhere that you want a cable with higher resistance? No clue if that's right or not. Anyone know?
I made a thread about this but nobody looked at it so I might as well repost my question here.
Here's the rundown of my problem, I am recabling a pair of headphones for my friend, the headphones involve a Y-Split with one cord going to each cup, and I did it the wrong way by cutting the cable so that there is 1 long cable coming from the jack, and two short cables coming from each cup, there are 3 seperate wires (I'm using Mogami 4 wire cable, but only using 3 wires.)
I don't have enough cable to redo it the proper way which involves just taking off an enormous piece of insulation and braiding it to each cup without any cutting, so my only real choice is to figure out some way to clamp all 3 wires together at the solder joint so that the cord doesn't break when you tug on it.
Any ideas? I can take pictures if I have to.
I used heatshrink - put the wire inside with some of the inner paracord strands - and seal it real tight. Then you can usually just pull the wire all the way through as you pull the inners out from the other side. Sometimes it'll break halfway through, but it gets me much closer, much quicker.
ok
i use adhesive shrink tubing which does a nice job
or you can individual heatshrink each solder joint cover it with
an old fitting or piece of tubing then another layer of shrinkwrap
it can be done so it looks neat and clean
i posted some links on this about 2 pages back
That's just normal Canare cable and connectors. So nothing special needed for digital RCA vs analog?
I did Canare star quad, which was 26 AWG. I used type 95 paracord. You gotta do the "inchworm" method. Took me about 10-15min (it got quicker as I got better) for each 6 foot strand.
Was type 95 too small? I'm concerned that 550 might be too big.
