DIY Cable Questions and Comments Thread
Aug 25, 2013 at 3:40 PM Post #212 of 10,535
Aug 25, 2013 at 3:53 PM Post #213 of 10,535
Aug 25, 2013 at 3:56 PM Post #214 of 10,535
Hm, improve my soldering or purchase a Gungir later in the year..
Aug 25, 2013 at 4:24 PM Post #215 of 10,535
Aug 25, 2013 at 4:34 PM Post #216 of 10,535
Aug 25, 2013 at 4:36 PM Post #217 of 10,535
What do you think I should do?
I have worked with the DHC stuff and honestly it is so far the easiest and best looking wire I have ever worked with.  It looked fantastic and soldered like a dream.
Aug 25, 2013 at 4:39 PM Post #218 of 10,535
Aug 25, 2013 at 4:46 PM Post #219 of 10,535
No, like save up for Gungir or get wire and supplies?
If you believe in wires they will make the smallest difference in your chain.  If you don't than they won't make any difference in your chain so either way I would go with the Gungir.
Aug 25, 2013 at 4:51 PM Post #220 of 10,535
Ok, cool, thanks. I'm still debating it, as I get a lot of experience if I purchase DIY stuff, and that's what I want.
Aug 25, 2013 at 5:05 PM Post #221 of 10,535
If you want some good expirience build a DIY amp.
Aug 25, 2013 at 5:30 PM Post #222 of 10,535
Aug 25, 2013 at 5:39 PM Post #223 of 10,535
Depends on the headphones but crack or sex.  For anything lower than 100ohms sex for anything higher than 100ohms crack.
Aug 25, 2013 at 5:41 PM Post #224 of 10,535
Aug 25, 2013 at 7:39 PM Post #225 of 10,535
It's all up to you young sir, I learned my soldering skills a long long time ago and they are a great skills to have.
The Gungnir looks like a nice DAC, well beyond my purchasing ability but if you are able to do so then go for it. Be warned though you will need a pair of LCD's as well to go with your new Mjolnir I remember right. :)
Building kits is another great way to learn to solder, which I would do before you jump right into a recable job on a nice set of headphones as you want the cable to look great.
For me wire is wire, there are others that claim they can hear the difference between OFC 4N and 7N but I cannot. :D
I don't know what you have for a soldering iron but I would look into one of the Hakko FX888's if you don't have a decent one.
Good Luck with your choice!
