65535
- Apr 23, 2007
Highly unlikely on both counts. More like 1x 26awg in micro and 4x twisted 3x braided in 550.
Hi guys
I have questions about choosing the size of paracord.
Um can a 6-braided 26 awg cable fit into the 550 paracord? And, is a micro paracord suitable for sleeving a 3-braided 26 awg cable?
thank you
Micro paracord was the perfect size for 1 stand of nucleotide DHC 24 gauge for me. I'm fairly certain it will be too small for a 3 wire bundle of 26 gauge.
Hi guys
thank you
anyone can suggest what to use for sleeving?
thank you
I think you're going to have a very hard time fitting those conductors in a single 550 paracord.. might want to look around the gallery to see if anyone has ever done it before.
What I would suggest is:
A. use 650 Paracord (http://paracordgalaxy.com/mobile.php?main_page=index&cPath=176_177) This should fit all 6 conductors. Note I actually have never tried this kind of paracord..
B. use 550 Paracord with 2 conductors in each and do 3 strand braid.
C. use 325 Paracord with 1 conductor in each and do 6 strand braid.
If you plan on using the cable as a cable then use 2893, if you are going to strip it use whatever is cheaper. 2893 is a miniature portable cable, 2799 is a console cable for installation work. The only difference is the outer jacket. Hard smooth PVC on the 2799 and soft satin PVC on the 2893.
