Which Y-splitter is that?
Looks like the Doublehelixcables Capsid: http://www.doublehelixcables.com/store/index.php?main_page=product_info&cPath=4&products_id=118 There are few samples out in the wild.
I'm looking to build a headphone cable with mini 4 pin xlr connectors at each headphone cup. Any suggestions for decent looking male 4 pin mini xlr connectors that doesn't cost more than say $30 for a pair?
Well, your options are actually quite limited. The only deluxe 4-pin mini XLRS are by Furutech and they are well over $30 for a pair. Beyond that you have standard Switchcraft, Rean (Neutrik), Amphenol, and the stuff you can get off of ebay or Aliexpress.
I will say that the Amphenols have been my favorite and are of higher quality than even the Switchcraft that they are clones of for half the price. Standard looking, but have a great feel and tight tolerances. I have used some off of ebay/Aliexpress that have been ok, and can be found with cooler shells, but the tolerances aren't as tight and sometimes they can get stuck. I have used these: http://www.ebay.com/itm/mini-xlr-4P-4-pin-female-Audio-Mic-connector-TA4F-0A-/351017765950?pt=US_Computer_Microphones&hash=item51ba4a0c3e and they were fine. You could always take the shells from the cheaper ones and use the guts of the Amphenols for a focus on quality and looks. Would still come in under the cost of even normal Switchcrafts.
http://www.supplycaptain.com/index.cfm?fuseaction=product.display&product_ID=74
That should be adequate for 26 awg.
I'm doing a 4 wire braid with 26awg copper and want to sleeve each strand individually with paracord. The micro paracord I ordered is too thin, or I don't have the patience to mess with it anymore, pick one. What size should I be using? I don't want it to be baggy. Thanks ahead of time.
Awesome that's perfect then, the Canare is 26awg. I can't imagine being able to use this "microcord" for wire, it starts coming apart as soon as I attempt to route anything through it.
When you get a clean cut, take a lighter and carefully melt the ends. This will keep it from coming apart. Also, make sure to have a clean cut of your wire with no strands poking out. This can catch on the inside and cause ugly snags.
