Dita Audio Flagship - "The Dream"
Dec 2, 2017 at 7:08 AM Post #451 of 544
WCDchee
Dream thread is quiet these days!
Had a question regarding the cable. I bought these from the classifieds and they came with the normal retail version of the Dita cable. Mine sticks out of the 2-pin sockets further than the photos I see in here. The seller mentioned it and I don't think it's a big deal or anything (he actively posts here too) but I wonder if it is actually different than the one bundled with the Dream. Anyone else have the issue where the cable protrudes out of the IEM further?
That said, I'm using the Rhapsodio Golden cable with them right now and my goodness, the ergonomics are so much better. I really can't stand wearing the Dita cable, but it just feels so wrong not to use it with these IEMs! :)
-Collin-
One of the things I so love about Dita is the fact that they never use off the shelf parts. Every element of the design is custom specced to their needs.
This includes the 2 pin plug connector and socket. Most companies use off the shelf comnectors and pins. As such the socket is almost always the same, 2 thin metal contact rings set in plastic, and these invariably loosen with repeated plugging and unplugging.
Now as for Dita, if you had a look you would see that they have extremely think chunky contact rings as sockets that are far less likely to loosen with time. Besides this, there are actually metallic spring leaves within the sockets which grip on the pins, enhancing contact and durability.
As a result of this, the stock cable pin design is actually slightly different from the standard 2 pin connector. The pins are longer, and are specially tapered in a way that actually makes them snap into the socket somewhat like what FitEar sockets do, albeit to a smaller extent.
That said, the dream is indeed compatible with standard 2 pin cables.
I would enquire about the stock cable with the previous owner if possible.
Dec 4, 2017 at 7:40 PM Post #452 of 544
Galm
Wanted to post an RMA experience.
So I was having issues with my left ear bud and sent it in to get fixed. They said it was measuring fine and sent it back. I was still having issues though and realized it was the cable connector.
I asked for a new cable and got it really quickly, and it instantly fixed the problem. So I was really happy with Desmond's responsiveness and helpfulness in resolving the issue!
Jan 3, 2018 at 5:54 AM Post #453 of 544
waxiboy
Hi guys..I pulled the trigger and bought DITA Dream the bad news is I have tinnitus and it triggers it...what can you suggest to lessen its brightness/sibilance or should I say make it warm..
Jan 3, 2018 at 2:26 PM Post #454 of 544
SeeSax
Bay Area, CA
Sadly I think this IEM is probably not very good for someone with tinnitus, but you can always try a warmer cable and/or Comply foam tips. I tamed the treble a bit on my Dream with a Rhapsodio Golden cable, but any copper cable might do the trick for you. Differences will be slight and you will lose a bit of that Dream resolution-magic, but it could be the difference of loving or hating the IEM for you I suppose. Check out something like the PW Audio no5 cable or the Rhapsodio Pandora Dwarf, two of my favorite copper cables.
And then I'll buy the stock VDH cable from you of course :)
-Collin-
Jan 3, 2018 at 4:39 PM Post #455 of 544
musiclvr
AZ
I would definitely look into purchasing the Comply Ear Yops with the Wax Guard filter. Those are probably the warmest tips around and, in my experience, helps to take the edge off of bright earphones.
Jan 3, 2018 at 4:43 PM Post #456 of 544
musiclvr
AZ
Jan 3, 2018 at 9:10 PM Post #458 of 544
nogi replicant
This is the main reason I sold them. Having tinnitus myself and having owned many in ears the only recommendation I have is Adel tech. Much better than Apex for tinnitus. Both of which are much better than no hearing tech at all. Something open back like the lcd i4 is also good. That is what I am currently using. But for a sealed iem Adel is the boss.
Jan 4, 2018 at 8:35 AM Post #460 of 544
waxiboy
Have you tried changing your cable with a pure copper cable? If yes is it still too bright for you??
Jan 23, 2018 at 10:39 PM Post #463 of 544
audiojr
Malaysia
Hi guys, I’m thinking of getting a aftermarket cable for the Dream. What are the options out there that provide better comfort (the stock cable is rather stiff) and offer sonic upgrades, while maintaining the same sound signature.
Feedbacks and suggestions are much appreciated. Thanks.
Jan 24, 2018 at 4:31 PM Post #464 of 544
SeeSax
Bay Area, CA
I'm not a fan of the stock cable either, but oddly enough I find the ergonomics of it much better on another pair of IEMs I have (Earsonics S-EM9) due to the angle of the socket.
My favorite cable with the Dream so far has been the Leonidas from Effect Audio (mine is sort of a one-off version), but the ergonomics of Effect Audio cables are generally very good; soft and supple and you don't really notice them. I have an Eros II coming in that I'm going to try with the Dream and can let you know on that. The Leonidas is pretty darn expensive, but then again these already come with a $500 cable. @PinkyPowers is also currently testing the Dream with a Leonidas I think, so maybe he can chime in on cables as well since he too did not fancy the stock cable.
-Collin-
Jan 24, 2018 at 9:20 PM Post #465 of 544
PinkyPowers
Reviewer: The Headphone List
Kansas City, MO
-Collin-
I agree. Leo is indeed a great, great match for DITA. I like the sound, and ergonomics better than the stock cable, if indeed you can call a $500 cable "stock". :)
