TheFrator
You need to listen to Animal as Leader's album Parrhesia if you haven't already!As I listen mainly to Instrumental Progressive rock and metal
I know but I was just making sure haha.It is almost impossible to listen to Instrumental Progressive metal and not know them!
I will give these artists a listen. Thank you!I love Scale the Summit, Sithu Aye, Intervals and also quieter stuff like Plini and Chon.
After posting that i struggled, i came across a thread (ie600) that suggested o-rings, i cut up the stem from an old surplus tip and made 2 thin o-rings which went onto the ie200 stem and obviated any tendency for the tip to switch. Having done that i much preferred the original position as the bass and richness of the music comes through better (imo) so i removed the o-rings.Yes I struggled as well. I think we are supposed to remove the tips first and then place the tips back on at either the outer or inner position. Another problem for me is that the tip position easily self-switches from the outer position to the inner position when placing the earphones in my ear. Not sure if there is a solution for this.
Yes the ie200 fit is excellent.After posting that i struggled, i came across a thread (ie600) that suggested o-rings, i cut up the stem from an old surplus tip and made 2 thin o-rings which went onto the ie200 stem and obviated any tendency for the tip to switch. Having done that i much preferred the original position as the bass and richness of the music comes through better (imo) so i removed the o-rings.
I have to say that the ie200 is the first normal iem that fits properly in my ear, previously i have used etymotics as they have always fitted well.
d
Does anyone feel that the ie200 bass sounds kind of “wet noodle” and artificial sounding?
Oh yeah the tips, please change the stock tips, with stock tips the bass is very anemic, change to my final E tips and OMG the bass is quite satisfying.
Thank you for choosing us and welcome to the #IE200Club!Another Senn in the bag!
Stay updated on Sennheiser at their sponsor profile on Head-Fi.
I use Final E tips and can confirm that bass is not lacking in anyway.Oh yeah the tips, please change the stock tips, with stock tips the bass is very anemic, change to my final E tips and OMG the bass is quite satisfying.
TrueI use Final E tips and can confirm that bass is not lacking in anyway.
