Dethonray Clarinet - Portable DAC/Amp Discussion + Impression thread
Jan 15, 2025 at 12:23 AM Post #151 of 423
Will that work with the USB-C from any device ?
Not any random device, the HiBy devices (and some other devices besides) are outputting a coax S/PDIF signal out of a spare pin on the USB-C, not all devices do this. Our own M300 doesn't, for example. The original 2018 R6 didn't, for example.
Jan 15, 2025 at 12:36 AM Post #152 of 423
How’s the power output of the clarinet? Been a fan of dethonray since the dtr but after buying a pre release of the sg1 the power output left me disappointed. Anson was cool and even made me custom firmware to max out its output and it could eventually drive the Mest mkii to satisfying levels but only in high gain with the volume knob maxed out.
So my concern on this is power
Jan 15, 2025 at 3:08 AM Post #154 of 423
The cable could not work! If the cable connect to clarinet, mean the signal connect to Ground. So you could hear a noise then no sound out.
The picture from @fx88 means clarinet is an unambiguous design , If there is COAX signal input for either the left or right channel, it can be received.
So the best way is a RCA output from source ,then use the clarinet RCA TO 3.5 adapter.
What you say makes sense based on the diagram indicated but that would be a non standard set up for absolutely no benefit and would only cause confusion.
That might well be the case of course.
I have the cable and a Clarinet on the way so I will advise is due course.
If it doesn’t work I will make a new cable to suit.
Jan 15, 2025 at 6:24 AM Post #158 of 423
Could anyone tell me if the Clarinet comes with an adapter for RCA to it's coaxial input. Hiby do a USB to RCA adapter and want to know if this will work or if I need a different Hiby cable. Thank you
Yes, Clarinet's package contains 2 adapters, one for coaxial and one for optical.
Jan 15, 2025 at 7:36 AM Post #159 of 423
Jan 15, 2025 at 8:16 AM Post #162 of 423
Hello all, has anyone listened to the Ibasso D16 and could give a comparison ? I know the price points are widely different but still.
I’ve owned both. The D16 is a very solid dac/amp. A bit more laid back. The price is difference is unjustified in my view. The clarinet is a great value for what you’re getting.
Jan 15, 2025 at 8:22 AM Post #163 of 423
Thanks, I see you sold the ibasso, was it not to your taste? Bare in mind that I usually the usually more natural sound of discrete DACs. What are your go to sources and IEMs today ? Just to have an idea of your tastes
Jan 15, 2025 at 8:24 AM Post #164 of 423
Different animal. D16 is high refinement, the most natural Dac, with a 320 max amp stage. The Clarinet is a $200 very musical little fella. If you have the gear to go along. The D16 is amazing. If you don’t, you won’t be able to squeeze the most out of it. I won’t be surprised if someone says the Clarinet is better.
Jan 15, 2025 at 8:32 AM Post #165 of 423
I use only IEMs, but high end. In general they don't need ultra high end source
