giveway
- Nov 4, 2008
Pulled the trigger on these.
I was worried about the small cups, but they fit my ears perfectly. They also may be very shallow, but even if my ears are touching the drivers, I certainly can't tell. Overall, no complaints whatsoever comfort-wise.
And now to the tricky part:
Out of the box, they were almost unlistenable. Thin sound and a very, very harsh treble. Which was a huge surprise, given the fact that most people have been talking about bloated bass and muddy sound before burning in. Mine sounded exactly the opposite! I did not panic though and was willing to make up all sorts of excuses: new headphones, my ears are not adjusted to them, they need burning in etc.
After about 40 hours of burning in (combination of pink, white and brown noise), I noticed a slightly more present bass, while the treble has softened a bit, but it's still quite harsh at times and definitely has an artificial timbre. Sibilance varies from non-existent to very present; another quite puzzling aspect. The details are there and all, but overall these hp make for a pretty uninvolving and, after a while, fatiguing and unpleasant listen.
I'm not a bass head or anything, but I prefer a warm and full bodied sound, which was exactly how people have been describing the AH-MM400. So far, it's anything but that. I'm willing to reach the 100 or 150 hour mark of burning in, but I doubt they will change that drastically and get a completely different sound signature.
ps) my setup: MacBook Pro--> iFI iDSD Micro-->AH-MM400, using flac files downloaded from hdtracks played in Audirvana+.
