Combover Grover
Let me know what you think. Hadn’t used eq on them until I saw the headphones.con review. It’s essentially resolve’s eq just dialed back a bit. Split the difference.Much appreciated! I will try these right now!
Depends on your sensitivity.Currently on the lookout for a second pair of headphones, the 9200s are great but can't wear them for extended periods or I get headaches. Where I am there's a decent deal on a TH900 PW and a Focal Radiance, or are they a bit too similar to the 9200? Could also get the Clear MG but I sold my OG clear due to being too fatiguing
Oh I should mention the headaches are from the headband, not the 9200 itself. I tried an aftermarket cover but no dice.Depends on your sensitivity.
I found Th900 more fatiguing than 9200, especially in the treble but it’s technically a super headphone with one if not best stage width and subbass.
Have you tried the aftermarket pressure relief elements to be sticked below the headband?Oh I should mention the headaches are from the headband, not the 9200 itself. I tried an aftermarket cover but no dice.
I assume it‘s not the clamping force at the side but the headband pressing onto the head.Try to stretch the headband on top of some box or something over night/s. It would lower the clamping force and makes them more comfortable. This works although I have not had any comfort issues.
Stretching out the headband would probably exacerbate the issue, since it would lower the surface area of which the actual headband is in contact with the head. As mentioned any sort of additional surface contact with the head would more evenly redistribute the weight of the headphoneTry to stretch the headband on top of some box or something over night/s. It would lower the clamping force and makes them more comfortable. This works although I have not had any comfort issues.
Yeah I have, I can only get the cover on my head, if I put the pad on as well it doesn't fit, that damned big headHave you tried the aftermarket pressure relief elements to be sticked below the headband?
I bought these but as my comfort is not Meze-like but still ok, I haven‘t even opened the box
Maybe you will come back.My D9200s are currently listed on eBay UK if anybody's interested. So far these are the headphones I've enjoyed and appreciated the most, so I'll probably regret selling them. At the moment I'm dabbling in high end open backs and might end up going all in (for me) and getting a set of Susvaras.
Here's a shot of my setup : PC Streacom DA2 > xDuoo XA-10 > Denon D9200 + Dekoni Audio Elite Sheepskin + balanced cable OCC silver + ROOMs Audio Line FS Pro
A little warmer : a bit more bass, a bit less trebble, mids sounds about the same to my ears.How would you describe the sound difference between the stock ear pads and the Dekoni?
