I'd definitely choose the D7200. Pads will make a big change on it, basically you can change the signature between linear, ideal and fun (V-shape) just by switching pads. Perfect.
The best stock pads IMHO are the D5200 pads (linear), followed by the D7200 pads (linear but overdamped and less musical), followed by Stax 009 pads (linear, big, lively, but more mids as well which may not be welcome by all).
The best overall pads are the modded D7200 pads (ideal), with the inner foam trimmed in thickness and inner diameter in order to have about 35-40% less foam inside the pads (D5200 pads need less trimming or no trimming at all). Instruments tone/pitch/harmonic structure is more natural. And there is the bass, as near to perfect as it can be from any headphones IMHO. The TH900 has more bass quantity, but extension and impact is similar.
The most fun signature is with Fostex TH900 pads but with carbon foam filling (see TH900 mods thread). Fantastic physical bass, more treble, big sound stage. However, the "ideal" pads go as deep, but with no perceived overshoot in the bass.
A balanced, big sound-stage, high resolution sound is achieved with the Stax 009 pads, especially if modded (see Stax 007/009 mods thread). These are the easiest pads to mod, but the most expensive (and highest quality).
Potentially very good replacement pads could be obtained from
https://vesperaudio.com/earpads, albeit I have not tried them. Among the choices, probably the perforated leather pads should work best with the D7200.
I have tried the following:
- the Chinese TH900/D7200 pads from ebay, have 4 pairs, all sounded different, they are cheap, but perhaps it's better to pass, the above are better.
- Brainwavz hybrid, leather and perforated leather pads, the above are better for the D7200.
- Lawton pads, the above are better for the D7200.
- ZMF Eikon and Ori pads, the above are better for the D7200.
- MrSpeakers Voce pads, the above are better for the D7200.
