Mr Trev
Inane thought o the day…
We have 12AT7, 12AU7, 12AX7. What happened to 12AV7 & 12AW7?
There is a 12AV7, but more commonly talked about as a 5965. Gain kind of smack dab in between a 12AU7 and a 12AT7. I've never seen or heard of a 12AW7. There's also a 6SU7 and a 6SV7, but no 6SW7. Maybe folks back then didn't like W's or something (and George W. Bush wasn't even born yet).Inane thought o the day…
https://tube-data.com/sheets/127/1/12AV7.pdf
ACCKKK!! A pentode! No wonder I've never seen one....I didn't want to scorch my eyes.Click the link and then you've seen all the heavenly glory that is the 12AW7
https://www.radiomuseum.org/tubes/tube_12aw7.html
…perhaps WW-I and WW-II sufficed to cause avoidance of the ‘W’ …….(and the ‘world wide web’ being a half-century later… )Maybe folks back then didn't like W's or something (and George W. Bush wasn't even born yet).
…I recall that, last October, Head-Fier @G0rt was successfully (enjoyably) rolling 5965s in his Schiit Valhalla II…There is a 12AV7, but more commonly talked about as a 5965. Gain kind of smack dab in between a 12AU7 and a 12AT7.
I've got some 5965's in the stash. Sylvanias I think. I bought them probably 25 years ago but don't remember if I ever listened to them. That's bad, I suppose.…I recall that, last October, Head-Fier @G0rt was successfully (enjoyably) rolling 5965s in his Schiit Valhalla II…
Lemme know if you try em in your Vali and are any goodI've got some 5965's in the stash. Sylvanias I think. I bought them probably 25 years ago but don't remember if I ever listened to them. That's bad, I suppose.
Same pinout as the other 12A's....perhaps I should try one. The Incubus didn't like the (much) higher gain of the 12AT7, but perhaps the 5965 is just low(er) enough that it'll work.
Going to be hard to beat the Footscray in the Vali, but you never know. Then again, in a $150 amp a $10 tube makes a wee bit more sense than a $120 one.Lemme know if you try em in your Vali and are any good
Incubus is apparently designed to utilize the gain area of the 6SN7, not the higher gain of the 12AT7. Kudos to @Paladin79 for a great design.I've got some 5965's in the stash. Sylvanias I think. I bought them probably 25 years ago but don't remember if I ever listened to them. That's bad, I suppose.
12au7 gain is close to 6sn7.12AU7 works fabulously with Incubus.
Yup, and fortunately my memory sucks. I have 5963's, not 5965's. The 5963 has a gain of 21 versus the 6SN7 gain of 20 and the 12AU7 gain of 19 - 20 (depending on which data sheet you look at) so these should work just fine in both the Incubus and Vali. I'll give one a whirl tomorrow.Incubus is apparently designed to utilize the gain area of the 6SN7, not the higher gain of the 12AT7. Kudos to @Paladin79 for a great design.
Roger that!Incubus is apparently designed to utilize the gain area of the 6SN7, not the higher gain of the 12AT7. Kudos to @Paladin79 for a great design.
