JKDJedi
So I've sampled every tube known to man....or most of them that are worth sampling.... am I missing out not sampling the Brimar?
YES !So I've sampled every tube known to man....or most of them that are worth sampling.... am I missing out not sampling the Brimar?
Absolutely! Go to the Schiit Mjolnir 2 threads to find out about Brimar, Footscray, and other wonders of the tube world…So I've sampled every tube known to man....or most of them that are worth sampling.... am I missing out not sampling the Brimar?
Danger Will Robinson! Danger! Danger!Absolutely! Go to the Schiit Mjolnir 2 threads to find out about Brimar, Footscray, and other wonders of the tube world…
Did you have a GE nightmare that caused you to post at 3:45 AM…poor thing!……Danger Will Robinson! Danger! Danger!
ROFL! It wasn't a nightmare but more of a delayed blessing. Couldn't sleep, so went back to work on the DV mods. Had a crap GE (like there's some other kind) in the new socket to keep the inner contacts aligned while I soldered to it. Got done with the socket, and when I pulled the GE out it slipped out of my hand and hit dead center on a 12x12 ceramic tile I had on the floor. Didn't shatter, but the getter went white instantly. Enough impact to break a seal somewhere. On the plus side it probably won't sound any worse than it did before, and on the other plus side it will still work just fine for soldering sockets.Did you have a GE nightmare that caused you to post at 3:45 AM…poor thing!……
Congrats. Yes, IMO the Crack is technically a step up from the DV. I strongly suggest that you try a shouldered (coke-bottle) power tube instead of the 6080. I'm running a Svetlana 6N13S currently. To my ears it becomes smoother (less rumbly) and more natural.First impressions are faster, more detailed and balanced sound than Darkvoice.
Yes. It works well, and mainly adds 3D depth and a sense of expanded space. [That's mainly what tube harmonics do.] The DV is a solid value as a preamp, just check the price of typical stereo-oriented tube preamps.Does anyone use Darkvoice as a preamp?
Congrats on the BHC. I found the speedball upgrade to be a pretty clear improvement as well. GEC 6080 in the power slot? I recommend the mullard cv4003 for the input tube. Of the few 12au7s I rolled I liked that one the best.It's friends, my new toy has arrived.
My Crack has Speedball installed.
Looking forward to starting the valve roll.
Yes you can run 6SN7s with an adapter.Does Crack support 6SN7 for input tube?
I am and it does a much better job as a pre-amp than a headphone amp in fact. Important is to set the volume a bit less than 1/4 all the time. A better and warmer dedicated pre-amp would be a Yaqin SD-CD3 driven by dual 6SN7 (Raytheon in my setup - @bcowen loved ones).Does anyone use Darkvoice as a preamp?
Do you know if it works well?
I also tend to prefer long plate 12AU7 tubes over short plate tubes, as they sound more neutral and less-bright. The Crack can lean toward brightness with some tubes, or at least an extended high range.
