- Jun 20, 2010
Amps only exist to make a signal louder and there is only one correct way to do so, so it is easily measurable. Have some common sense.
If you're using a poorly measuring $2000 amp (distortion generator) to "tune" your sound and call it "synergy" or pretend that makes the amp better than a cheaper, better measuring one, you're misleading everyone into wasting their money.
Most amps, DACs and cables will sound identical, but people think they hear all sorts of differences because they're not good at comparing sounds and let their overconfidence tell them otherwise.
Don't use food as an analogy. You know or at least should realize that the comparison makes no sense. The music analogy to the ridiculous thing you said would be trying to measure how good a album is based on the waveforms alone. That of course requires personal preference, something that has NO BEARING on if an electric signal is repeated or amplified correctly or not.
I swear this place only exists as a safe haven for nut jobs.
