I had a Susvara and TH900, sold the Susvara, bought the Stealth, then sold the TH900.
I believe the Stealth and Susvara are about the same in terms of bass impact though they present bass differently.
I believe impact is essentially loudness.
You may be thinking "but wait, there's no correlation between impact and frequency response". Well, yes if you don't factor in time.
Sounds don't immediately stop once the input says they should. The driver still has inertia and there are still reflections inside the cups. This is why dynamic drivers tend to produce more impact. They tend to take longer to stop because they generally have more mass and are pushing on more air. It's not just the instantaneous loudness, but the duration of the loudness that creates the impact. We're talking about milliseconds here so the delay isn't noticed as a delay. Frequency response over time can be measured. The plots are called waterfall or CSD plots.
The Stealth is incredibly fast with almost no reflections which results in a "tight" sound.
It has increased bass volume to make up for this.
The Susvara isn't quite as fast and has some resonance or reflections in both the bass and treble. It has lower bass volume, so impact is about the same in the bass compared to the Stealth while the treble might sound a little more punchy due to increased treble volume/impact due to ringing.
This is why some people might hear the Stealth and not like it at first. It's extremely fast and accurate, to the point of sounding dry compared to headphones that smear the sound a bit. It's why audiophiles often call the smearing "euphonic" or "musical" and purposely seek out high end amps, especially tube amps, and DACs that measure poorly and smear sound.
One of the benefits of the Stealth's quickness in the bass is incredible space between sounds that slower headphones tend to blur, aka "muddiness". The soundstage isn't wider, but imaging is much better defined as a result.
Sure, the soundstage on the Susvara sounds more open because it's an open back design, but it doesn't match the Stealth in speed and tonal accuracy. Ringing in the treble will give added volume/impact and the appearance of detail but it isn't speed. It will muddy up the rest of the sound, despite possibly sounding euphonic to some.
So the question is, do you prefer accuracy or artificial impact/euphonics?
