ThanatosVI
You had a shower heater plugged in where your audio system is !?New tweaking journal condensed version:
1.Unplugged the Aircon:
-Less midbass thiccness...less hardness on vocals. Slightly peaky. Sustain on vocals a bit veiled (far). Bass notes moves lower and have more definition. Gives the presentation so much grounding that it feels like I'm listening to speakers or live band in a room.
2. Unplugged my powerstrip that's usually off and housing my chargers and laptop wall wart
-More purity on the sustain of vocals. Peakiness is gone. Much smoother. More convincing bass tone and density.
3. Unplugged shower heater and now in pseudo dedicated mains mode where everything but the audio chain is unplugged
- more relaxed. Shower heater takes less of a hit on SQ like the microwave.
Tweaks in-between that didn't work anymore
-i was reseting some of my devices to 'freshen up' the sound and make it more linear. But since unplugging the Aircon, this doesn't work anymore. Doing it now makes things peaky.
-i was using Oyaide ac plugs to help with the peakiness at the start but I don't need that anymore as well with psuedo dedicated mains mode. Using these plugs didn't make the LCD4 sound good at all too.
Here's the interesting part. LCD4 has some peaks in the bass and upper mids. This perceivably cuts the rest of the neighboring frequency. I have the new pads and while it's less resonant, at this level the group delay is more apparent especially when comparing to the Stealth. Vocals are not clear and is like the singer is singing through a short tunnel.
Stealth actually sounds more open than the 4. There's more linearity and smoothness in the bass so the quantity and sustain is proper. The thicness on the mid bass is lesser than before so it sounds more open than the 4. Vocals are clearer to the level of good iems with no group delay distortion that it sounds open again. On that midbass thiccness I was hearing before with the aircon plugged in, I thought it was the way the albums were mixed and I'm hearing it properly for the first time.
Once again, the Stealth is so good that it really helps me diagnose the rest of my chain. It is also the only headphone I've heard that gives proper grounding to the presentation. Most other headphones are too floaty. All the tweaks and exercises are about balancing the sound. The goal being, no emphasis on anywhere in the frequency band.
