801evan
Yep. Too many ppl have fried their susvaras with speakers amps because it is not needed and is overpowered. While AHB 2 may sound comparatively better than chord HP out, it is not the ideal approach especially with Chord gear because the Dave and hugo 2 has enough power for the Stealth and Susvara and you are throwing all the quality of the WTA and transparency out of the window by using an external amp which simply adds a lot of color, second harmonics and the interconnects would just cut the bandwidth on the top and bottom extension and collapse the soundstage. The better method is use the stealth on the HP out and improve the transport, digital chain and power quality.Hi, Ok, I did not know that,
I thought it was needed for for low impedance HP, also it does assist to convert speaker taps to XLR as a convenience but if it does create an additional barrier to better sound I am willing to test it out, anyone out there who have used Stealth or similar HP without any adapter/resistor in between? A bit scared as one person on the Susvara thread blew up his HP's....
The He-6 adapter will indeed have a big hit on transparency and sounstage due to the amount of plugs in the chain and the resistor.
