If you need isolation, then better to get the Stealth. After applying the EQ, any difference disappears 10 seconds after going into the music, which is why I am thinking of selling one of the 3 (we have 2 Stealths and 1 Expanse).
So for the people with both the Expanse and Stealth, does the Expanse actually sound the same (or very close) to the Stealth with the EQ setting Dan suggested? Or does it actually sound better since it’s semi open?
I don’t prefer that sound signature but just wondering for those who don’t need total isolation, would the Expanse be more versatile? You can remove the EQ when you want to rock out but apply it if think sounds better for classical. Seems you can’t really turn the Stealth into the Expanse but you can turn an Expanse into a Stealth.
In the flip side the Stealth can be more versatile since you can use it in a noisy environment. But do think Expanse works great at home even when there is some background noise going on. You don’t need completely quiet room.
I think Nomax already addressed this. He says you can easily EQ the Expanse to sound very similar to the Stealth. But you can’t EQ the Stealth to sound like the Expanse because it’s CLOSED back. If you try to add that bass shelf, it gets boomy with too much cup resonance etc.
Yesterday, I received my Double Helix Cables Complement C adapters to use with my Complement C cable with the Expanse. Up until now, I was using the stock SPC (silver plated copper) cable. In my opinion, the 7N OCC pure copper Complement C cable is better in every meaningful sonic attribute. Soundstage width and depth are better, midrange and treble purity are much better and the bass is better too. Most importantly to me is the coherency is better. I mean that the bass, midrange and treble blend seamlessly together and sound like they are cut from the same cloth making the listening experience totally immersive. I didn't get that to the same effect with the stock cable.
Don't get me wrong, I thought the Expanse sounded good with the stock cable but I felt it could be better. I recommend that if you have a pure OCC copper or pure silver cable, that you compare it to the stock cable. If you don't have one, perhaps you can borrow or buy one on a trial basis. As in the past with other stock SPC cables (Audeze and Sennheiser SPC cables come to mind), I feel that they are not as good as pure copper or silver headphone cables. I have several other brands of cables made with pure copper or silver such as Wywires Platinum and Norne Silvergarde but I have yet to try them. Just thought I would share my cable experience with Expanse owners.
You shall not add a bass shelf to Stealth to make it similar to Expanse, as Stealth has more subbass and less midbass. The right way is explained by Dan as below:
Sorry, doesn't make any sense, as even a 5 dB bump is not a much difference, let alone a 3 dB bump. This is a difference you can even adjust with a slight volume rise and with your description it would have resonance issues even with a slight rise above the average listening volumes, which is neither neither audible nor measurable.
But what does "too much air mass" mean? There are two mistakes here: 1) In order to make it closer to Expanse, you should add a bell, not a shelf. 2) Also with your description, if you increase the volume by 3 dB, you should break the bass. This can only happen if a) You are listening extremely loud that is deafening levels (considering the 94 dBSPL THD is below 0.5). b) You have a faulty driver.
Movin air mass...by this I mean how strong this behaves...the pressure created by the air mass...just listen to the track (lily) then you know what i mean
The more you increase the more you think a hairdryer blows in your ear
NOMAX
PS.here no moving air mass
Sounds great with expanse and with stealth
NOMAX
"Too much air moving", meaning too much bass, not boomy cup resonance bass, which is pure nonsense and also false information. Also as mentioned before, Stealth has a quite present subbass. To make it similar to Expanse, you need to increase the 100-300 Hz region only, not below.
Exactly. They are very close. Also as Dan mentioned Expanse needs 1-2 dB more than Stealth for achieving the same volume level, which makes it difficult to compare HPs that are so similarly tuned. I put on the Stealth, I feel center image is close (inside your head) and then I put on the Expanse and it is slightly further away. Then I remember to adjust the volume and they are more similar sounding and my ears adjust etc. etc. Then it is also more about the psycho-acoustics. I don't feel confident enough to emphesize more than just the bass and low mids.
