Second time I've posted these measurements of the Diablo.
iFi's site claims:
The Diablo L7 tested reached 600mW and about 4.5V at 32 Ohms before clipping. iFi claim that it will output at least 12.6V and 4,980mW. That's 12% and 36% respectively. Ok, I was off by ... 2%.
For the Stealth and Expanse, let's say you listen at around 80dB. To allow for peaks, the amp should be able to output at least 100dB without clipping. So, for those headphones, that's 50mW and 1V to get to 100dB. Looks like, for the most part, we're safe.
However, what if you have someone who likes to rock out a bit and do some listening at 90dB? Well, then you arguably need 500mW and 3.4V to ensure that you have enough headroom (to reach 110dB) for music with a large dynamic range. That means, there's a chance that someone who runs the combination will have the amp clip. As I've stated before, this is easily possible if you listen to music which has unusually large amounts of low bass, such as movie soundtracks. I found that it was possible to easily go over 100dB SPL with a movie soundtrack of this type without any discomfort, due to the perceptive loudness of different frequencies being different, which will send something like the Diablo into clipping very easily. Again, the large SPL was the result of the very low frequency bass notes. I'm sure if I filtered that out, the rest of the music would nowhere near that SPL level, as I wouldn't have been able to listen to it.
What is more, clipping, which is when the amp starts dumping raw DC into the output, can damage your headphones. If there's a chance an amp will clip with a pair of headphones (at listenable levels) it is totally unsuitable to recommend it!
Note: I didn't say that you can't reach ear-splitting levels of loudness with the Expanse or Stealth and the Diablo.
I didn't say you should listen at over 100dB.
I didn't assume anything.
I'm not implying anything.
I'm not talking about anything that isn't mentioned in this post.
I'm only saying what is in this post. Nothing more or less.
For the 14+ years I've been on Head-Fi one fact has not changed: You can listen with full-sized headphones with portable gear, and it may be OK a lot of the time, but most portable gear is not completely ideal for use with full-sized headphones and wont be as cable as desktop-class amplification. There aren't any contradictions if you have good reading comprehension.
