Mar 27, 2025 at 6:32 PM Post #2,731 of 2,787
I am looking for an upgrade to my A2 Noire on the closed back side.
I have auditioned E3 vs Atrium Closed recently. In my opinion both are excellent. My problem is that on the open back side I have HFM HE1000SE – one of the best headphones on the market. Their biggest flow is that in comparison, most other headphones sound “vailed”. The resolution, sound stage projection and holography are simply outstanding on HEKSE. If you like precision, more analytical detailed sound, IMO E3 is a slightly closer to HEKSE and possibly a better choice. However, the more I listened to Atrium the more I liked it. There is something seductive in their sound that pulls me in. I will probably go with Atrium.
I recently got HEKSE and was always wondering what if I could have gotten E3. So I wanted to know people's opinion who have heard both of them. I tried Atrium Closed for a while but I realized they were too laid back for me and sounded not wide enough for my taste. I tried heavy EQ on HEKSE specially on treble region and added a bass shelf that really helped them. I wanted to get Utopia but as per the review they have intimate soundstage and was really putting me off. I'm also curious about Abyss Joal but not much info about them so far.
Mar 28, 2025 at 1:37 AM Post #2,732 of 2,787
I have a pair of DCA's Ether2, which is a great planar headphone. I'm wondering if the E3 can also be driven by a portable DAP like the Ether2. Most of the time, I use the ONIX Mystic XP2, a portable DAC/AMP combo.
Mar 28, 2025 at 11:54 AM Post #2,733 of 2,787
I use the FIIO KA17. Runs it fantastic, at less less than half volume. It's a *very* small portable little USB device, but is *not* battery powered. Works best connected to a laptop with plenty USB power. On a phone it struggles due to lack of USB power, and I have to turn the volume all the way to max. Still sounds good, but it's obvious it's pushing the amp to the limit.
Mar 31, 2025 at 1:59 PM Post #2,735 of 2,787
I'm driving the E3 off of the single ended jack of the Fiio JM21 DAP and it sounds great and I'm sure the 4.4 balanced jack will be even better.
Apr 2, 2025 at 9:03 PM Post #2,737 of 2,787
This is really surprising! Is the JM21’s output that powerful? In that case, if the E3 must be used with a portable DAP, it seems like it might actually be feasible. :beyersmile:
Apr 3, 2025 at 9:16 PM Post #2,739 of 2,787
AK SP2KT works great. Even tried it wirelessly with a Ifi Go Blu and it sounded good to me.
Fosi DS2 or Tanchim Luna will drive an E3. I’ve got a Fosi D2, ifi xdsd Gryphon, and FiiO Q15. Amir at Audio Science review showed the Luna s the second most powerful dongle and the DS2 was around 4th most powerful. My gryphon clips with the E3 on bass heavy tracks, but the DS2 and Q15 work on all tracks.
Apr 3, 2025 at 11:23 PM Post #2,740 of 2,787
How much E3 leaks sound to outside vs. Noire X? I mean Noire X does not leak at all, can you listen E3 when there's others around?
Is E3 harder to drive than Noire X?
Apr 4, 2025 at 8:45 AM Post #2,741 of 2,787
E3 is about the same with regards to noise leakage as the Aeon/Noire series, which is very good and no issues listening with others around. E3 is harder to drive. For example, on Mojo2, it takes four extra clicks (+4dB to get to double orange, which is 0.12v) to achieve the same level.
Apr 4, 2025 at 9:01 AM Post #2,742 of 2,787
ASR has a sensitivity comparison. Look at the Noire X review and go two thirds of the way down to the green bar graph.
DCA Headphones Sensitivity (mv for 94dB, higher number is harder to drive)
Ether CX 145
Ether Flow 1.1 164
Noire X 333
Aeon Noire 353
E3 512
Stealth 549
Expanse 665
Aeon RT 677
Dan Clark recommends 1watt at 32 ohms for the E3. The Noire X recommendations are 250mW at 16 ohms.
For comparison:
Hifiman Susvara 1290
My E3 sounds great with a Fosi DS2 or FiiO Q15.
Apr 4, 2025 at 9:51 AM Post #2,743 of 2,787
Ether CX 145
Ether Flow 1.1 164
Noire X 333
Aeon Noire 353
E3 512
Stealth 549
Expanse 665
Aeon RT 677
For comparison:
"The maximum single-ended power outputs [see Graph 1] are 89mW/600ohm (voltage limit), 1190mW/32ohm and 2225mW/8ohm (current limit), all perfectly in line with Naim's rated 1500mW/16ohm."
https://www.hifinews.com/content/na...hone-edition-streamerheadphone-amp-lab-report
So, my Naim Uniti Atom HE should be able to handle E3🤔
It drives Noire X very easily.
Apr 11, 2025 at 3:56 PM Post #2,744 of 2,787
I found the E3 to leak considerably more than the NX. When I covered the top vent holes on the E3, it leaked much less so that's the majority of the leakage. For my preferred listening levels, E3 would definitely bother my coworkers.
Apr 12, 2025 at 12:03 AM Post #2,745 of 2,787
Thanks for the info. I'll continue with NX then.😊
