- Aug 15, 2011
I also have a Mac and yes it supports AptX & AAC (as to be expected). If you have a Mac, try searching and installing Bluetooth Explorer. It'll let you configure a few other little details :-I'm not sure this is still true. Supposedly windows 10 have support for APTX from some update, but the problem is they don't give you option to check which codec (SBC or APTX) is currently in use, at least yet.Depends on how you connect them. See below in order of increasing SQ:
4 - Via Bluetooth: there currently are almost no PCs that support Bluetooth codecs better than SBC. Macbooks do support APTX, but one has do do some tweaking to have that codec enabled. There are however USB Bluetooth dongles available that support APTX(-HD). So generally speaking, making the most out of the DALI when connecting via Bluetooth requires additional technology
![Screen Shot 2019-12-14 at 20.56.55.png Screen Shot 2019-12-14 at 20.56.55.png](https://cdn.head-fi.org/a/10396646_thumb.png)
Yep you'll have to troubleshoot why your iO-6 mic is visible but not functioning. I'm sure it's just a setting somewhere on Windows settings.Well I'd want to use it mainly in discord or facebook calls. The thing is, like I said, even in system's recording devices list they are visible, but no sound is detected from them. Dali's mic is of course marked as default to use. I'm not sure what can I do to make it work, but at least now I know it's possible.
Edit: Damn, quoting is so problematic when editing my post... I totally destroyed it for one moment...
One more thing, as I forgot about it - when i first tried my new pair of IO-6, there was some very noticeable white static noise, even when ANC was turned off. I was afraid I might have to return them for another pair. Then, In the next few hours of use it started to disappear from time to time and in the end of the day, I didn't hear it anymore. Is this normal?
I've not heard of any static noise on my iO-6 when I first had it.
