wslee
Member of the Trade: Qudelix
Some users asked me about the Bluetooth version of ES100.
ES100 supports Bluetooth 4.2.
But, I'd like to let you know that Bluetooth version of any audio receiver(sink) or transmitter(source) is nothing to do with sound quality or audio streaming link range.
Bluetooth audio streaming over A2DP(Advanced Audio Distribution Profile) always goes with Bluetooth Classic link,
that is BR(Basic Rate)/EDR(Enhanced Data Rate).
Bluetooth classic (a.k.a BR/EDR, basic rate/enhanced data rate) came out to the world first
and then Bluetooth Low Energy (a.k.a BLE) next.
The trade-off between data throughput and power consumption was the primary reason for the birth of BLE.
In comparison with Bluetooth Classic (0.7~2.1Mbps),
BLE has application throughput around 300kbps in order to save the power consumption,
which is not fast enough for the stereo audio application.
ES100 supports Bluetooth 4.2, and the ES100 mobile application communicates with ES100 over BLE.
However, audio streaming over A2DP(Advanced Audio Distribution Profile) always goes with BR/EDR,
not only with ES100 but also with any others A2DP receiver/transmitter.
Any mobile phone always delivers the audio packets over A2DP thru BT classic BR/EDR link,
no matter what version of Bluetooth it supports.
New Bluetooth 5.0 is an upgrade version mostly for the low energy (BLE).
However, even with the assumption of the new data rate of 5.0, doubled from 300kbps, it is still not fast enough for A2DP.
Because A2DP generally requires around 1Mbps application throughput regarding error and retransmission in the interference environment.
Some vendors take and claim the Bluetooth v5.0 as a competitive/essential advantage of their audio application product,
misleading the users as if v5.0 would provide something better.
If the application is a wearable device like Fitbit which deals with arbitrary user data over Bluetooth,
the version is matter, and the latest BT version will provide you many benefits including range and power consumption.
However, with the A2DP application, you will get nothing better with the latest BT version.
Even any lower version of BT would perform the same when streaming the A2DP.
Hope this helps you.
Thanks and Regards,
WS
Thanks and Regards,
WS
