DjAmTraX
Now known as: HiFiGuy528
- Nov 2, 2010
Why was the original DM such a hit?
Thanks Gwarmi. I am looking for an extra DAC for my Realiser setup and it looks like the DAC Magic plus will not be it. I have to reconsider the Antelope Zodiac Gold with Voltikus power supply.
does this new dac sound as good as the dacs in the 840 c cd player if it does i will get one for my pc and use with grado ps1000s?
[size=small]I conducted an A/B/X test a number of years ago with three knowledgeable sound experts; a drummer for a semi-known rock/jazz band, a sound engineer, and the audio rep for a world famous speaker company.[/size]
[size=small]The purpose of the test was to determine if the average but sound-knowledgeable person could hear the difference between the USB, Optical and Analogue outputs from the Macbook Pro into the CA DAC Magic.[/size]
[size=small]We selected equipment that was somewhat high-end.[/size]
[size=small]The test included an Apple Macbook Pro, Cambridge Audio DAC Magic, McIntosh Integrated Amplifier (either the MA 6600 or 6300, sorry I forget which model exactly) and Tannoy Dimension TD 8 (grills off).[/size]
[size=small]We used three pieces of music, jazz, rock, and classical in the AIFF format.[/size]
[size=small]Key to any A/B/X test is the volume. The volume level was matched for each input so that would not colour our results. Remember the purpose of the test was to see if somewhat knowledgeable people could hear a difference between the USB/Optical and Analogue outputs on a Macbook Pro.[/size]
[size=small]Of the three, the output that performed the best was the optical. Hands down it won every single time on every song. To our three panelists it was the winner.[/size]
[size=small]Now here comes the surprise... the analogue output sounded second best![/size]
[size=small]And by far the worse... the USB. Time after time the USB failed to impress all three participants. Every song... every time. At one point I switched USB outputs on the Macbook Pro cause I thought something was wrong with the port cause the results for USB were so bad![/size]
[size=small]So was it the Macbook Pro's USB output? Or the DAC Magic's USB input? Who knows... I'm not an electrical engineer, but I will say this in my experience, I have NEVER heard acceptable audio quality from a USB port and I've used half a dozen USB audio interfaces in a dozen Apple computers.[/size]
[size=small]I might someday... I plan on getting the DM + soon, but until then my USB ports are dedicated to printers and cameras. ;^)[/size]
One of these, it makes the 'USB Jitter' gremlins go away ~ some DAC's just absolutely need one, more often than not
USB integration on sub $1500USD DAC's can be hit and miss. Some like my old Arcam rDAC sound best from USB.
Blast! Now i need one of those when I was previously content. Do they actually make a noticeable difference to the sound quality?
Seriously a USB to SPDIF which costs about 2-3 times the price of the DAC on review? What an utterly pointless investment, I mean if your running from a source that doesnt support optical/coaxial you'd be better putting the money there. If the USB interface on the DM is so poor (as I believe it is) then all the jitter correction in the world wont make it great. unless you've run the DM+ from any other input you really havent heard it. So in short you've listened using phones only - while the units being wired to its worst input ....seriously lopsided effort at best. I think you'll find when proper reviews start to hit the net they'll do staged listening through the various input configurations.
Finally a few people going on about the M-Dac which is by all accounts a very fine piece of kit and in a completely different price bracket here in the UK - so try comparing apples to apples. If you actually think you've dodged a bullet I'd take the 'review' on here with a large pinch of salt.
