bigshot
Not just a light... A MCINTOSH light!
You can pay for it with three handy $500 payments!
I dislike hiss actually. I can hear it.I'm not sure about AK, but I have the three other ones you mention. Same experience.
I have a R2R too! I can hear hiss with that.
It was the best format back in the pre-digital era.
Someone can hear the movement of the his computer mouse using a Topping E30 DAC. The DAC gets the power from a PC USB port. How is that possible if only 0 & 1 bits?I dislike hiss actually. I can hear it.
That's nothing. I can hear the movement of my computer mouse without even using a DAC! I think it's probably due to the friction between my mouse and my mouse pad.Someone can hear the movement of the his computer mouse using a Topping E30 DAC. The DAC gets the power from a PC USB port. How is that possible if only 0 & 1 bits?
PCs are the ultimate bad noise source. It's quite a feat when a device doesn't show the nasty electronic noise.Someone can hear the movement of the his computer mouse using a Topping E30 DAC. The DAC gets the power from a PC USB port. How is that possible if only 0 & 1 bits?
Which speakers are you using?The proper combination of components matter, but I think you would be very hard pressed to find a DAC, DAP, disc player or amp that doesn't produce sound better than human ears can hear. The transducers are the wild card. You'll need to make sure you are using the right amp for your transducers, particularly with IEMs. But beyond that the main difference between electronics is features, not audible sound quality.
I have Oppo PM-1s and a really good screening/listening room with a multichannel speaker system. I've compared DACs and players from the Oppo HA-1 and BDP-103 to a ProTools workstation, to all manner of Mac stuff, all the way down to $100 Sony and Pioneer blu-ray players and a $40 Walmart DVD player.
Headphones and speakers all sound different. You have to spend money to get quality there. But price in electronic components dictates features, not fidelity. A $5 DAC chip is audibly transparent and most electronics are made from the same stock off the shelf parts, all of which were designed to be audible transparent.
On most of DACs, 0 & 1 is transmitted through the USB cable as a signal along with the power and ground signals to establish a reference ground (logic 0) and 5V (logic 1) voltages. When the signal voltage is reasonable close to 0V (ground) or 5V, it is interpreted as logic 0 and 1. I think E30 DAC also gets its own 5V power supply as well. To figure out if the signal is close to reference 0V or 5V, some DACs will ground (connect together) both USB ground to its own power ground from the power supply. However, the computer has tons of devices connected to its own USB power and ground and sometimes the noise is transmitted through these USB devices/peripherals since they share common ground and power and sometimes make these ground or power to fluctuate little bit. DACs generate output voltage based on these 0s and 1s and they rely on the accuracy of their output voltages on how stable is their own power supply voltage. Hence, these small fluctuation will vary the DAC's output erroneous and these can be heard as a noise through the DAC whenever attached device to your PC generate the noise on the USB power grid.Someone can hear the movement of the his computer mouse using a Topping E30 DAC. The DAC gets the power from a PC USB port. How is that possible if only 0 & 1 bits?
You might care to check what FPGA is:Fpga dac chips are far fsr better, in measument and clear audiable traits, no doubt. The market wouldn't work otherwise.
AFAIK, actual bit errors are very rare comparatively to the massive amount of data being read every hour. I'd expect maybe a handful over hours of measurements so I really can't imagine how that would be the cause of us hearing noises. Also they would need to be consecutive errors, or the fluctuation would only be able to create really high frequency as the error. It just doesn't seem to align with testimonies of noises heard.On most of DACs, 0 & 1 is transmitted through the USB cable as a signal along with the power and ground signals to establish a reference ground (logic 0) and 5V (logic 1) voltages. When the signal voltage is reasonable close to 0V (ground) or 5V, it is interpreted as logic 0 and 1. I think E30 DAC also gets its own 5V power supply as well. To figure out if the signal is close to reference 0V or 5V, some DACs will ground (connect together) both USB ground to its own power ground from the power supply. However, the computer has tons of devices connected to its own USB power and ground and sometimes the noise is transmitted through these USB devices/peripherals since they share common ground and power and sometimes make these ground or power to fluctuate little bit. DACs generate output voltage based on these 0s and 1s and they rely on the accuracy of their output voltages on how stable is their own power supply voltage. Hence, these small fluctuation will vary the DAC's output erroneous and these can be heard as a noise through the DAC whenever attached device to your PC generate the noise on the USB power grid.
On good DACs, there is an additional circuitry to eliminate the noise transmitted through the signal (0/1) and/or through reference ground/power lines. On a slightly less than ideal or more affordable designs, these circuitry do not exist or not sufficient to suppress these noises as generated by the PC mouse.
Sorry about your wallet but the most safe and accurate solution can be buying another DAC with better noise suppression or provide 0s and 1s using an optical connection from PC (if exist) so that there are no noise transmitted to the DAC.
