If you are fine with your FW10000 then you'll be absolutely fine with the A8000. Give it a shot. My ears are sensitive to treble, hence the impression. I'd take a pair of A8000 if I have something neutral or warm as my daily drivers, and just use the A8000 when I want some wow factor. But I wouldn't take it if it is the only pair I have to live with.
Honestly guys, I'm pretty close to pulling the trigger on the A8000. There's just some intangible aspect about it that's drawing me to it. It looks like Final is awesome for customer service and the company's vision is awesome - I kinda wanna support that.
It's hard to compare the fatigue factor between IEM and HP because of multi-BA phase issues. Jerry Harvey talked about this in a video that I can't remember off the top, but basically at the same level of brightness on FR, IEM is more fatiguing than HP. With that, I'm fine with HD800S bright but not A8000 bright.
Is there an IEM that could match Utopia detail retrieval/dynamics/pin point imaging ? Tonality must be good at least as I'm sensitive to any harshness and want to avoid any dry sounding IEM's . Utopia actually hits the sweet spot for me without being tiring. Now I'm not fully aware how far IEM can go in terms of performance, but I do have earsonics em10. It has nice tonality, but lacks on technical side of things and quite by a large margin when I compare it against Utopia. Most importantly though it sounds a bit dead and boring with electronica.
The price range would be up to 2000$ and I can go via used IEM market as well. Through short reviews I drilled down to theaudio Monarch, 64 U12T, 64 trio, Andromeda, Empire Ears Legend X(more excited for the good bass and hoping to match utopia tech) ?
I'm a bit worried to rush into a sidegrade with a bit different flavor. Unfortunately I've got no chance to audition any IEM either
Just to give the wheel one more spin…
It seems like you’re putting a lot of thought and energy into this decision. It doesn’t seem like you want to purchase and part with this set in under a month.
I have the U12t and IER-Z1R and MEST mk1. I’ve also auditioned the A8000 and could have bought them used for almost 50% off.
But you know what gets the most play. My custom fit IEMs. There’s something about a perfect fit that makes them so much easier to put on and keep them in. They always have a perfect seal and I don’t have to adjust them as I go through my day. Customs are like bionic IEMs.
You’re clearly going to make an investment in yourself, so why not jump in with both feet?
And don’t try and go half way and get custom silicone tips, because they’re not as comfortable as acrylic.
Yes I'm mainly using my custom IEM EM10 too, the comfort is on different level compared to universals that I had. No need to worry about tips and fit issues, but EM10 do sound a bit too soft. I quite enjoy them over my desktop equipment and strangely they have good synergy with mojo. So as of now I'm looking into DAP upgrade which would pair nicely with EM10
