There is a reason for this I will try to explain.
I would like to clarify what is going on here, with the speedball implementation.
Traditionally, this is called a "CCS" circuit. "Constant Current Source"
Look it up. Yet, from a designer's point of view, the end main result will cause less harmonics, and so "clean up" the sound.
This equals
less tube sound..a less thick or what amouts to less "euphoric" sound.
there are also other ways to have less tube (harmonics) sound. Elimination of a cathode cap is another.
The main strength of tube holography stays regardless of how "clean" it will sound.
So choosing option of "speedball", should really be an option of how much
color, or
richness in sound that you prefer...
From a designer's perspective, it should be viewed as a signature choice, rather than an "improvement".
I would say that the crack as an amp is as worthy as any amp to keep regardless of other expensive amps, if you prefer it's signature. Dont think just by buying a more expensive amp, you will be any more happier, if you already prefer the crack..
Yet
resolution is another matter. If you want higher resolve, then you just have to focus on the most prominent places for sound upgrade. All amps can benefit similarly from upgrades...
So were? the coupling cap, and output cap areas are main areas that what you wanna upgrade for higher resolve.
Resolution is different from noise level, or added harmonics. There is a vague misconception that fixing all other things in an amp, will bring you higher resolve. It may change and add performance to the resolve, but it basically that's not raising it.
For instance, we can lower noise floor, and lessen harmonics to give a "cleaner" sound, but that's not increasing Resolution. We can add more dynamics with larger caps, but that's not increasing Resolution.
Those are separate added aspects.
So basically, if you prefer the stock non-speedball sound, then you would like thicker amps.
Beware the illusion of going up the "price" ladder with other amps would be any better.
You should try and listen to them first, because many top amps have even more bloom and thicker or euphoric sound.
As most sound observations are "subjective" my comments are only my opinion, and should be put in perspective, as your ear and experience is what matters in the end. If there's anything I would want you to know, is that you should not second guess your observations for others. Believe your ears
