NoName1
- Aug 15, 2014
@zach915m Should consider making bottlehead bases to go with his headphones. I know I’d love a cocobolo base to match my ZMFs.@JamieMcC I was inspired to build the ziricote base because of the ziricote ZMF Aeolus headphones I bought from @zach915m. I reached out to Zach to get help on the products and process to achieve a matching finish, so basically all of these tips are thanks to him! I'm planning to post a build write up on the base as I have a bunch of pictures of the process and final product. Right now I'm having too much fun tube rolling with my new Bottlehead Crack, so here's the quick rundown:
Let me know if you have any more questions! This was my first time doing this type of a wood finish so had a lot of questions going into it myself...
- Sand up to 400 grit then apply Mohawk pre-catalyzed sanding sealer
- Sand up to 1000 grit. For the high grit (500-4000) I used the abralon pads used for bowling balls that Zach recommended
- Apply 5-7 coats of Mohawk pre-catalyzed semi-gloss clear lacquer, with light sanding at 500-1000 grit between coats - as needed to remove any bumps in the lacquer and definitely before the last coat goes on. The more you sand off the more coats you'll need to apply... Use a tack cloth to clean up dust between each coat, esp after sanding.
- After the last coat dries, sand up to 4000 grit. I dry-sanded first and eventually wet sanded everything again, which turned out better.
- Let the lacquer cure for a little over a week and then apply the Mohawk penthouse polish. I underestimated how much of a difference the polish makes! You can see after / before polish in the two pics below.
Here's the other base and Aeolus after applying the penthouse polish to both:
Fully assembled crack, BEFORE polishing the base, with all black furnishing & powder coated top plate & transformer:
