audiowize
- Jan 20, 2008
The heat dissipated under the chassis goes up when the Speedball is installed.Have you installed the Speed Ball?
Then with SB upgrade the pair of wirewound resistors were removed, and I believe the plate temp dropped significantly.
The localized heating of the chassis plate right where those 10W resistors sit will decrease when the Speedball is installed.
(Always remember to install the rubber feet too)
