CAPT Deadpool
Glad you figured it out. Would p**s me off if It happened to me. THAnks for posting the problem you probably won’t be the only one
It has been a while since I've touched my beloved bottlehead crack amp. I'm looking to get back to regular music sessions, but I think my crack needs some help. It's the stock crack with speedball, and I've replaced the smaller tube with a new Mullard 12au7 ecc82. I'm experiencing consistent ringing and humming noises in the left channel. When I press or wiggle the big power tube, I can get it to go away for a short time. This was always the case after I assembled it almost 2 years ago, but I'd love to solve it once and for all. Does anyone have any tips on what I can do? Thanks fellas
atomicbob's nuclear crack system:
My crack is non-speedball, has power supply choke mod, re-biased for Tunsram e80cc driver, and larger than normal output capacitors, which requires care during power up (headphones disconnected until warmed up.)
HD800 J-mod headphones (originally modified by mikoss.)
Here is a hot-rod analogy to what this system is like:
so heres a question before i finalize this thing the 9 pin front socket is your a bit loose under the mounting ring? i have it as tight as it will go and the 9 pin really moves around a good amount in the hole like if i shake the plate the 9 pin rattles? the other socket is nice and snug without being to tight. im torn on the top plate finish still.
i have not fully snapped in the switch or the wall sockets yet so i can easily get them out. im thinking a orange or titanium chrome vinyl over the top or polishing it or an actual hammer type finish (you can achieve this in the aluminum but it takes a long time and is super tedious i have a friend who is a blacksmith who showed me this type of finish before) or leave it bare just because i like the look. hmmmmmmmmm. lol i was going to just anodize it at first but now im undecided haha
i do have a custom real carbon fiber top plate being made for the second kit i have here that should be interesting. ill have to run a ground for everything since the top will not be metal though
I got a vintage 12aT7 I pulled out of an old philco radio. No idea if it works
