CAPT Deadpool
MAster shake i mean tha drizzle. My 9pin is solidly attached to the metal plate. My socket soldering loops move a bit but not the socket itself. Did you put the retaining ring on top?
That does not sound right, can you post a photo?I am using the retaining ring and it's as tight as it's getting and the white socket moves around a good amount inside the retaining ring. The larger socket is solid as can be. It is also mounted on top as it said in the instructions.
