Crack;Bottlehead OTL
Mar 26, 2018 at 12:48 AM Post #9,091 of 12,346
In my opinion, a properly functioning tube should not be microphonic. The 12AU7 input tube contains all the gain so it will be more susceptible, but there's nothing about the Cracks's topology that makes it more sensitive to microphonics. I have probably a dozen input tubes and maybe 1-2 of them are microphonic.
I think the issue is with external vibrations, like say banging on a keyboard or walking around near the table where the Crack sits. I forgot that I could not keep the Crack on my desk as I hit the keys on the keyboard pretty hard. I keep the crack on a table next to my desk.
I should also mention, and this is more of a personal thing, but I did not like the idea of reaching around the tubes on the top plate to turn the amp on or plug in a cable, or plug in the quarter inch headphone connector. All inputs on mine are on the back, controls are on the front, and my headphone jack is on the side in one inch oak. I do little to add any vibration even if it is just adjusting the separate left and right volume controls.
The way I, and I think most others, orient the crack is to have the volume and jack on the front and the inputs and power on the back. While the input tube is a little close to the volume and jack, I wouldn't say I have to reach around anything to use volume, jack, or power.
Mar 26, 2018 at 6:18 AM Post #9,092 of 12,346
IMG_2507 - Copy.jpg I know the positions and as I said, it is a personal thing just like preferring a separate volume control for each channel. I would be reaching up there twice as much and I would need to put the second control somewhere. I did what felt right for me. Also I did build a stock crack amp and used it to compare to one I began modifying, I wanted to be absolutely sure that none of my changes affected overall sound. After that I pretty well knew the build and went on to modify a few of them.
I did put a blade switch on top in another build but it just controls magic eye tubes and aesthetically it is not meant to be mounted vertically. This is the only photo I have handy but the white blade switch is on the bottom left amp.
I envisioned my build before receiving the kit but that is just the way I think. My third build required some thought but I designed my own circuits. I should not even call this one a Crack amp, I just used a few left over parts from previous builds. It has 8 tubes, not the standard two.
Apr 3, 2018 at 11:56 AM Post #9,093 of 12,346
Good day everyone,
I recently purchased a BH Crack w/SB upgrade.
I'm currently using Tung Sol 7236 and Telefunken 12AU7. The sound is a great balance between warmth and clarity, but I'm missing bass slam and punchiness (the bass slam seems near non-existent).
I've been looking for tubes that might help the situation out: https://www.ebay.com/itm/2-MULLARD-...017926&hash=item33e634c724:g:BlIAAOSwxyJav8fc
Has anyone had experience with these tubes?
Impressions?
Thanks!
Apr 3, 2018 at 12:12 PM Post #9,094 of 12,346
Good day everyone,
Impressions?
Thanks!
The tubes you linked to are 6DJ8 and are not compatible with the Crack at all.
From my experience, the 7236 is the culprit here if you're looking for more bass slam. The 7236 is a very linear sounding tube with fast, well controlled bass, but it's flaw is that the bass lacks depth and slam.
I would look at a Tung Sol 6as7G to replace the 7236. And if you like that sound and want a more expensive variant with better sound, look at the Tung Sol 5998.
FWIW I've rolled almost all the higher-end tubes in my crack and my favorite combination is the Siemens Chrome Plate 12au7 + Tung Sol 5998
Apr 3, 2018 at 12:17 PM Post #9,095 of 12,346
Bendix 6080wb
Thanks for your quick reply, much appreciated!
How does the overall sound signature sound with your favorite combination?
I was also looking at the 7316 ECC186 Amperex? Any impressions with that one?
Apr 3, 2018 at 12:20 PM Post #9,096 of 12,346
I also am realizing that the 5998 is a bit too expensive at the moment, are there cheaper alternatives that offer similar sound?
Apr 3, 2018 at 12:29 PM Post #9,097 of 12,346
No problem!
Siemens + 5998 is just a great combo with the HD800S. Holographic imaging, wide soundstage, fantastic mids, no sibilance, neutral but with deep bass. I rarely roll any other tubes in my crack at this point if that tells you anything :)
The Amperex 7316 (mine is a Beckman labeled tube, short plate with halo getter) is my second favorite tube :) However, 7316 have gotten insane in terms of price and I really don't think they are worth the money. I prefer the Siemens Chrome plate anyways, and they can be found for around $50 easily.
Another great tube to look at that is very reasonably priced is the Sylvania 5814A w/ 3 mica. They have a gorgeous midrange that really makes vocals shine.
Apr 3, 2018 at 12:32 PM Post #9,098 of 12,346
The Tung Sol 6as7G is basically a 5998 but with a bit less detail. I ordered mine from vacuumtubes.net for $20 a few months back
Apr 3, 2018 at 12:49 PM Post #9,100 of 12,346
Would these be correct?
EDIT: I apologize for the back-and-forth as this would probably be handled better in private messages.
Apr 3, 2018 at 12:50 PM Post #9,101 of 12,346
Apr 3, 2018 at 1:46 PM Post #9,102 of 12,346
Good day everyone,
Impressions?
Thanks!
I like the TS 7236 a lot as a 5998 alternative...especially since they can be picked up for around $25-30!
Have you considered pairing it with a 6SN7?...Maybe a KR V-231 or a NU Black Glass? (need Garage1217 adapter, as well)
I'm running a 7236/TS Mouse Ears combo myself on The Crack/SB (plus choke/diodes/films) and it is quite nice.
There's also the question of which phones you're using, of course. I use mine with T90s and HD700s FWIW.
-Mark in St. Louis
Apr 3, 2018 at 1:59 PM Post #9,103 of 12,346
-Mark in St. Louis
I'm using the HD 800S
Apr 3, 2018 at 2:05 PM Post #9,104 of 12,346
I have quite a few 6SN7 tubes as well, along with the garage 1217 adapter. Overall they have a much darker sound signature than 12au7 types, which can be quite nice with the HD800. I rarely use them though because they tend to be more prone to microphonics and have a higher noise floor in my crack.
Of the 6sn7's I have, the Tung Sol Mouse Ear, and Sylvania JAN VT-231 are my favorites.
Apr 3, 2018 at 2:38 PM Post #9,105 of 12,346
I thought the Tung Sol 7236 was a ruggedized 5998. I also thought, based on reading about them on the Bottlehead forum a little, that they sound the same.
I'm currently using a Tung Sol 7236 and a Telefunken ECC82 (12AU7), and I'm not lacking for bass, but I don't listen to EDM or anything like that.
