Quadfather
I am still marveling at the dead silent, black background after replacing the tubes in my Bottlehead Crack amplifier!
Honestly I do not find a lot of difference between 6080's or comparable tubes compared to the 12AU7A's so I just usually say something like "they work well". Audio is pretty subjective and if you are happy with a certain set of tubes that is wonderful. I have gone as far as to buy Tung Sol, Chatham, Mullard and have tested in two identical Crack amps sitting next to each other (I did both builds). I used a switchbox and the same set of headphones so there were few variables. I was hard pressed to find enough difference to justify spending $200 for a tube compared to the $10 for a new 6080 or 6AS7G. YMMV
You get good original tubes with the kit and in buying a lot of used tubes and supposed new old stock, occasionally I would get some that did not perform as well as the originals but that is the nature of tubes, they only last so long.
Toooo bad, my friend. I hope you will find a pair of output and driver tubes meet your needs.Honestly I do not find a lot of difference between 6080's or comparable tubes compared to the 12AU7A's so I just usually say something like "they work well". Audio is pretty subjective and if you are happy with a certain set of tubes that is wonderful. I have gone as far as to buy Tung Sol, Chatham, Mullard and have tested in two identical Crack amps sitting next to each other (I did both builds). I used a switchbox and the same set of headphones so there were few variables. I was hard pressed to find enough difference to justify spending $200 for a tube compared to the $10 for a new 6080 or 6AS7G. YMMV
Nope, it should cost similar to a 5998. Check the eBay price history for reference.I will try to check those out sometime. I just found some on Ebay in the $200 range, I would hope they sound better and yours is certainly an opinion I would trust.
Soon i will be doing some more testing using local grad students from a very good school of music, I have RCA, Tung Sol, Chatham, Russian made etc. I am always curious what those with younger ears might find to their liking or if I can even get consistent results. I will then try the same thing with different 12au7 equivalents but I need to stock up on more of those before I do testing. It is just to satisfy my sense of curiosity but if people are just as pleased with a $10 6080, why invest in a $100-$200 tube? It is a given that buying old or used tubes can be tricky. Are you really getting new old stock or even tubes in decent condition? I sold my tube tester years ago but I have been meaning to reinvest in a good one, at least that way I am more likely to compare apples to apples. In a few years I shall retire and probably do a bit of consulting but I may consider building custom headphone cables, or selling tubes that I have tested and certified. I will probably say no more than here is a Tung Sol 5998, here are the test results. Cables are even trickier, I would talk about materials and construction techniques but it is always up to the individual to say 7 N OCC copper sounds better than high strand litz or a specific brand of OFC. I would never do that as a seller since some things are pretty subjective. On tubes I guess I could say, this particular brand or type is a favorite of my testers, or folks whose opinions I trust YMMV. As tubes become more scarce, their values will no doubt rise, I can think of worse investments lol.
You can set an alert on ebay.Cool I will look around more when time allows. I just looked through the first page of listings, and there was an auction that may be more realistic.
There are other good amp kits available for DIY.I know. I have used EBay since it’s inception and a similar company prior to them that lacked their foresight. Some of the higher priced tubes may not sell just like the listing for Crack amps at $650, they may be there for quite a while lol. An item is only worth what a person is willing to pay for it.
An interesting test. However, ....I will try to check those out sometime. I just found some on Ebay in the $200 range, I would hope they sound better and yours is certainly an opinion I would trust.
