barontan2418
Thanks Jamie. Yes I do have a soldering iron but not certain I could identity those joints applicable to right channel. I did not assemble the myself. Thank again for your reply.
I would try the things that the others have mentioned before worrying about bad components. If you have other tubes that would be my first move them on to the others . No one can diagnose your problem from here you have to try some things first. Good luck though.Thanks Allen.In your opinion could component failure be just as likely as a cold joint to cause loss of right hand channel audio after approx 15 min of play?
Building your own amplifier is not something to look at as extra effort.
It's more fun hobby-wise. It helps you understand the technology you're listening to.
Crack is a great choice to start with.
The biggest advantage of building a crack is everything that comes after.
And in that, the options are limitless. Flavouring, seasoning and refining it's sound to your personal taste.
It's a very versatile amplifier for high impedance headphones.
It's all about the journey!: http://www.head-fi.org/t/476650/crack-bottlehead-otl/7800#post_12695818
I use a ODAC with my Bottlehead Crack and a HRT MSii+. Both work well and I can not tell any difference. There is no real need to spend more money here IMO.
Alex
