I have a 6AS7G tube that has a very low noise, whistle etc that if I gently tap on the tube will go away for several minutes and sometimes for hours, but when first using it I go thru the process of letting it warm up and then after 30 minutes or so the small buzz is there in the background...not that annoying when listening except with low passages of music u hear it and of course is annoying to a purist etc...
I have a really clean build been doing this stuff for 35 yrs +...solder skills are excellent here.
But I did all the normal stuff you do, check for joints, everything tight, clean tube pins etc....even different rooms, power sources, cables etc...even re-soldered the power pin connections that look absolutely stellar.
With the original 6AS7G the noise is always there very low....if I gently squeeze the top portion of the coke bottle the sound changes tone/frequency...and sometimes disappears!! Ha!
I bought a second like tube from amplified parts in Arizona (great place to deal with). I got a 1953 NOS tube, still in the 1949 RCA wrapper/package.
Fired it up and it is very sensitive and touchy for 30 - 40 minutes upon power up, it tests very well on my tube tester. But it is really touchy and has all kinds of noise that eventually settles out but always comes back in some shape or fashion.
When listening I often hit pause to see if the noise or hum is there, and most often it is....it sounds like 60 cycle AC to me at times, Its there even with grounding plugs in the RCA input jacks.
So I have one 6AS7G tube that's not too bad, sounds just great, its just that low hum/noise in the background that drive me nuts!! LOL.
The second tube is worse and I have a replacement coming from amplified parts, these people are wonderful to deal with and sent out a replacement immediately!! No questions asked. Great customer service!
Having dealt with many tube amps in the past....the old tube worts games is still here alive and well!!! Ha!
That said its worth the minor pain and worts, the crack still sounds wonderful even with not perfect valves!.
The speedball constant current "upgrade" is not yet installed but I will do this in the near future...
Just wanted to share....
Alex
